Speedometer not working
Old May 16, 2009 | 03:37 PM
derecules's Avatar
Default Speedometer not working
Ok, So I replaced my speed sensor and my speedometer still doesnt work can anyone help me out with this problem PLZ
Old May 16, 2009 | 03:39 PM
derecules's Avatar
Default Re: Speedometer not working
My tranny is a 96 gsr tranny by the way
Old May 16, 2009 | 03:47 PM
xwhitchx's Avatar
unplug the plug from it, then pop out all the pins and clean them with something that can srach up the surfes of the conecting points, that will fix it
Old May 16, 2009 | 03:49 PM
derecules's Avatar
I will try that tomorrow it just started raining and I ccant get my car in the garage because my wife blocked it thanks though bro I will let you know how it turns out aaight
Old May 16, 2009 | 03:57 PM
xwhitchx's Avatar
alright, but yeah im 99% sure thats it, it have happened to me two times and 1 to my friend, it did work befor tho right, then it just stared going off and on when you are driving?
Old May 16, 2009 | 06:27 PM
derecules's Avatar
Yes it was working before and then it fluctuated between 40 and 80 then just quit working all together . What makes it get dirty though? I was told that it could be my ECU causing it but I dont really know ?
Old May 16, 2009 | 07:07 PM
Former User's Avatar
What year Civic? Is the CEL ON?
Old May 17, 2009 | 07:21 AM
derecules's Avatar
Yes I have a CEL but it is on for another reason BECAUSE OF THE CRANK ANGLE SENSOR . It is a 96 with a ls vtec with b16 pistons and a stock gsr head . The check engine light has been on every since the first time I got my original GSR rebuilt IT IS JUST A LONG STORY THAT I DONT LIKE TALKING ABOUT BECAUSE I HAVE SPENT SO MUCH MONEY ON THIS CAR !
Old May 17, 2009 | 08:13 AM
derecules's Avatar
How do I pull the pins out without feeling like I am breaking it lol
Old May 17, 2009 | 09:38 AM
derecules's Avatar
Ok So I cleaned off the connections and i forgot the order that they go back on can anyone help me out with this . I am talking about the connections that go to the speed sensor HELP ME PLZ
Old Oct 1, 2009 | 08:50 AM
chinner519's Avatar
New User
I have a civic dx which I am currently trying ot get ready for safety...
The last thing I need to fix is the speedometer, I only works when it wants to? Sometimes it works fine without bouncing around or anything and sometimes it simply reads 0. Any ideas on what I should look at first?
Thanks
Old Oct 1, 2009 | 09:13 AM
Lasky's Avatar
theres a small gear in the transmission that makes the speedo sensor spin and work.. sometimes that gear can be worn or missing teeth causing the speedo to not work at all or work randomly or bounce the needle around randomly.. if the pin cleaning doesnt work that would be the next spot to look
Old Oct 1, 2009 | 12:10 PM
chinner519's Avatar
New User
thanks, tried both... thought it was working for a few km but cut out again. I guess I'm gonna try checking the harness leads with a ohm meter?
Old Oct 1, 2009 | 12:11 PM
chinner519's Avatar
New User
if they're fine I'll try a new sensor?
Old Oct 1, 2009 | 01:10 PM
ferio252's Avatar
My friend had a similar issue and for him it ended up to be a loose speed sensor under the intake manifold.
jaconlon1
Mar 5, 2012 10:42 AM
chrisccm
Jul 30, 2007 09:55 AM
slow4dr
Dec 24, 2004 07:07 AM
stehigs321
Oct 6, 2003 08:02 AM
Ladysman_civic
12
Feb 27, 2003 11:36 AM
