clutch alighment HELP!
Old May 16, 2009 | 11:41 AM
DualCamEJ's Avatar
Default clutch alighment HELP!
fixed it
Old May 16, 2009 | 12:02 PM
1992Si's Avatar
Default Re: clutch alighment HELP!
IMO your going to have to pull the tranny and see what's going on.
You say alignment...If it wasn't aligned you couldn't get the tranny on.
Check the
Oh... I'll bet an axle popped out.
Check them.
Old May 16, 2009 | 12:04 PM
RunninEg6's Avatar
checking the alignment isn't that hard at all as long as you have an alignment tool. it's the dropping of the tranny out the car that's gonna be a bitch for if that's all you had to do. i made sure to check it just before i did my swap. axles could be another reason. spindle not catching on diff
Old May 16, 2009 | 12:15 PM
DualCamEJ's Avatar
yea the axles could be a problem. im going to have my friend come by and check on it.
Old May 16, 2009 | 12:18 PM
RunninEg6's Avatar
when checking axles make sure the lock rings are snapped into place. a good tap w/ a mallet will do and try tugging...shouldn't pull out
Old May 16, 2009 | 11:30 PM
DualCamEJ's Avatar
it goes in gear and revs, is it the axles really?
Old May 17, 2009 | 02:12 AM
waaBAAH's Avatar
no..its not the axles..its the axle.
Old May 17, 2009 | 02:23 AM
1992Si's Avatar
Yes, when you snap an axle the car will not move but it will go in gear.
When the axle pop's out of the dif, it will not move.
From my experience it's mostly the passenger side axle.
Like RunninEg6 said, if you have to, take a 2X4 (block of wood) and a 3 or 5lbs hammer, jack the car up from the lower control arm, keeping the axle level, put the block of wood over the axle nut and give it a wack. That should seat the axle in the dif, as long as you didn't snap the dif end of the axle.
Were these OEM axles or replacement ?
bmxkills
Jan 30, 2011 08:53 PM
Jdm John
Dec 12, 2009 12:51 PM
cfoamcvc
Feb 15, 2007 07:17 AM
Death_to_Thieves
Aug 24, 2004 09:39 PM
cjames235
13
Aug 22, 2003 04:50 AM
