Rubber Injector Insulator on IM?
Old May 15, 2009 | 09:06 PM
Charlie Moua's Avatar
Default Rubber Injector Insulator on IM?
I just have a couple of questions:
1) Are B & D series injector insulators the same? (they sit inside grove of the intake manifold)
2) What would happen if I did not use them?
3) Would the injectors get too hot?
The reason why I asked is become I just got done doing a Skunk2 IM install on my gsr.
(see i've searched already)
If I use the rubber injector insulator, the injector does not sit deep at all...Not like this picture below me. The only way for mine to look like that picture is to competely remove the rubber insulators.
Old May 15, 2009 | 11:36 PM
eg_21's Avatar
Default Re: Rubber Injector Insulator on IM?
yes d and b series insulators are the same, i just used my old d16z6 ones for my b16a2 IM, if you don't use them you will have a fuel leak in your manifold, they should fit alright with the insulators, do you have a pic that shows how they sit in your IM
Old May 16, 2009 | 07:24 AM
just going back to edit thread....
Solution:
I found out you just have to really press hard for the injectors to seat deep into the rubber seals.
kpjo4
Apr 15, 2010 10:15 AM
non-VTEC
Mar 13, 2010 09:55 AM
j_civic
10
Nov 24, 2008 08:17 PM
THEUSED
Oct 31, 2005 06:36 AM
sneakypete
Jan 31, 2004 10:39 AM
