Bogging and misfiring, what seems to be the problem?
Okay well this morning when I started the car It started up fine but soon after it idled rough, I let it sit for a bit and it idled and would misfire from time to time. It seemed to me like the car wanted to turn off. I drove it around a few blocks and it would jerk, and bog down pretty hard.
I checked out the injectors to see maybe I wasn't getting the correct fuel but they seemed fine reading at 12 on all four. One thing I noticed is one fuel injector has alot of build up around and a rubber seal ripping. I also decided to change the fuel filter since I never changed it on this car and that didn't help.
There is no CEL so I don't really know where else to start looking. How do I check if the spark plug wires are good?
Running a chipped ecu and the engine is a 95 gsr I'd really appreciate any info.
Since its to dark to go out and check the car I just pulled the plug wires and tested them inside. OHM test reads
Plugs / Readings
4 ---- 3
3 ---- 4
2 ---- 5
1 ---- 6
I can hear some clicking when I turn the car on, so it has to do something with the ignition right?
Plugs / Readings
4 ---- 3
3 ---- 4
2 ---- 5
1 ---- 6
Okay so I checked everything and the spark plugs looked pretty much done with, I went ahead and bought some spark plugs and wires (local auto store didn't have cap & rotor) and changed them. The car now runs great, thanks for helping me out guys!
