turbo+high mileage d series question...
I am thinking about strapping a sc6152e on my d15 with over 300k on it that runs perfect and leaks and burns no oil. The engine is always well maintained, and I have a random turbo set up sitting around, if I strapped it to my engine and ran about 8psi would it be safe? Atleast for a couple months? I was saving it to throw on a k24, but that wont be for a while, so why not throw it on the d15 for ***** and giggles, and if it blows later on just swap in a d16, and if it lasts long enough just throw the k24 in...
the main question is is it worth it to throw a turbo on a 300k+ engine and run low boost?
the guys above me are right its not going to last long with those miles. Then again you have to think to yourself, a d series is only couple hundred then just throw in a 1.6 like you said. A friend of my is doing something similar just boosting the **** out of his 1.5 till it blows then throwing his 1.6 in.
no problem man. Your right though most people on here would rather put you down then actual help but then again they probably dont have the knowledge to help.
it's usually the elitists that are negative, just because i cant afford to build a crazy engine doesn't mean i'm a fool when it comes to engines, i just wanted to see if anyone knew how strong a d series with high miles can be and what it can take
