the EJ8 guy again: Putting in tranny fluid
Old May 14, 2009 | 02:15 PM
o0Riffraff0o's Avatar
Default the EJ8 guy again: Putting in tranny fluid
ok... there are things i know and things i don't know about putting tranny fluid in....
back in the day i had a 91 CRX si, on which the tranny seized up on me so me and my buddies had to swap it out.... however, we found a 80-something 4 speed tranny that we threw on in a pinch for time... we had to *** the whole car to the side and put the tranny fluid in through a bolt hole in the tranny... it waqs annoying because we never new when it was full as we used a turkey baster due to our lack of funnel tools
then there is the 92 and up trannys that just have a dip stick for the tranny fluid level of which you can just apply fluid with ease... but my tranny dose not have the port... damn
and now the fluid question: there are three types of civic trannys from ef to eg to ej/ek... and so far i know of gear oil, standard 10w30 that can be used, and iv just been informed for mine there is some special fluid that i have to use for 98 and up.... i just went and got 4 quarts of it....
GOTDAMNIT... i just looked at it right now and this foo gave me tranny fluid for an "Automatic" WTF!.... well after i go and take it back, i need to know how to put it in "the easy way" if there is one... and if i really need to use "***** wonka's special blent of tranny spices" fluid
Old May 14, 2009 | 02:38 PM
sde780's Avatar
Default Re: the EJ8 guy again: Putting in tranny fluid
honda mtf is great, fill it up with a funnel and tube to the fill hole or vss hole
Old May 14, 2009 | 02:44 PM
EG6k24a2's Avatar
New User
if you want good transmision fluid, use amsoil synchromeser. Works well. My tranny shifts smoothe like butter.
Old May 14, 2009 | 03:21 PM
what kind of wrench would i use to get the bolt off
Old May 14, 2009 | 03:55 PM
waaBAAH's Avatar
10 mil for vss..then lift out vss
3/8 rachet end for side hole
Old May 14, 2009 | 04:03 PM
EG6k24a2's Avatar
New User
if the end of the 3/8 rachet is too short from your access point, add on an extension, and use the end of it.
Old May 14, 2009 | 04:12 PM
RareSpirits's Avatar
add some stabilizer to the trans for longevity.
Old May 14, 2009 | 04:18 PM
BryanM.'s Avatar
Resident Gearhead
the drain bolt fits a 3/8 rachet, the fill bolt is 17mm.
Old May 14, 2009 | 07:58 PM
cool... i got it done... i just went and got some gear oil... it mad the most sense to put what goes in there, in there
the 3/8 worked just fine... the plug was just on there extra dumb tight, i almost pulled the car off the jack f'ing with it... but yea no more grinding
Old May 14, 2009 | 08:51 PM
waaBAAH's Avatar
gear oil? use regular motor oil for your tranny.
faster Type R
Honda Civic (2006 - 2015)
Nov 11, 2009 04:12 AM
mikeintegra93
Jan 9, 2009 04:12 PM
KnightX
Mar 15, 2007 01:17 PM
.one lane
May 2, 2006 05:38 AM
