dump tube needs welding???
Old May 14, 2009 | 08:14 AM
GSE980's Avatar
Default dump tube needs welding???
My dump tube from my wastegate re circ back into the cat but it is just slid into place...I am thinking that exhaust is leaking from this there for giving me false readings on my wideband.... would this be okay to weld together or is it slid into place for a reason
Old May 14, 2009 | 09:13 AM
4cefed's Avatar
Default Re: dump tube needs welding???
Well it should have a flex tube inline if its going to be welded solid.
Old May 14, 2009 | 10:34 AM
92_civic's Avatar
its meant to be a slip fit to allow for expansion when the pipe heats up when the gate opens...if you want to weld it then you need to have flex pipe in the system or it will crack
or run an open wastegate dump and weld the exhaust where the wastegate routed into it
KevronsEG
Mar 8, 2004 04:38 PM
boondockgtr
Nov 13, 2003 10:00 AM
udctown
Sep 13, 2001 07:50 AM
