Ready to go Turbo kit... where? which one?
Old May 13, 2009 | 07:56 PM
notsoslow's Avatar
Default Ready to go Turbo kit... where? which one?
I want to boost my b18b1 integra. i want to buy a turbo kit that is ready to install right out of the box and the only thing i might need is a tune. where can i get one?
Old May 13, 2009 | 08:11 PM
vinceg143's Avatar
Default Re: Ready to go Turbo kit... where? which one?
did you get a compression test done
Old May 13, 2009 | 08:13 PM
spoolin94ls's Avatar
google it, ebay or the for sale section on ht!
Old May 13, 2009 | 09:05 PM
TheShodan's Avatar
Moderator
you'll need to find the right kit based upon the goals that you're looking for. What you've asked is very vague. Hondas are one of the few aftermarket platforms where you have an infinate number of choices. You'll need to investigate what fits your needs first before asking such a question.
I've posted a bazillion times what one needs to look for when it comes to the right equipment. Search around if you'd like based upon my screename, k?
Old May 14, 2009 | 06:51 AM
Turbocivic94's Avatar
I recommend Synapse Turbo. Great price and great product
Old May 15, 2009 | 01:00 AM
notsoslow's Avatar
how much whp does 1psi produce on a stock b18b1 engine? 10%?
my main goal is to have a reliable setup. i dont want so much boost i have to worry about my engine burning or blowing a gasket and what not. lets just say i want the car to have a turbo setup as if it came out to the dealer with one already. for example like a wrx or miata... something reliably kinda fast. maybe 180whp-220whp.
Old May 15, 2009 | 05:12 AM
fasteddy089's Avatar
1 psi? why waste the time. there are tons of b series kits out there that will produce power and be reliable on a stock motor. just have to make sure you have a good tune.
Old May 15, 2009 | 05:24 AM
jhammond_82's Avatar
Reject Papi
http://www.xs-power.com i think thats what i'm going with. decent prices.
Old May 15, 2009 | 05:47 AM
cvcrcr99's Avatar
So, I click on that XS power link, and get a home page. You want which set-up exactly?
Does the "complete" kit come with an Intercooler, charge piping, injectors, fuel pump, resistor box (if applicable), ECU management, a good tune, gauges, oil lines, colder spark plugs, vacuum lines, dumptube? Many kits do not have this included.
Your b18 should have no problems running 6-7 lbs. on stock internals with a good tune. I have seen stock b18's take up to 12lbs. of boost (on a good tune, cannot stress that enough).
If you only want 1 psi extra, you might as well snake a hose from the intake piping into the cabin of the car and blow in it as your driving. Also, good luck finding a wastegate that allows a minimum of 1 psi, the lowest I have seen is a 4 lb. spring.
Old May 15, 2009 | 06:07 AM
UK Accord's Avatar
Quality
Old May 15, 2009 | 07:56 AM
ScorpionT's Avatar
Haha. I think he was asking about how much power per pound of boost, not saying he wants only 1 psi.
Be more specific with how much power you want, how much you want to spend, whether you want a high quality kit or ebay stuff, etc..
Old May 17, 2009 | 02:11 PM
notsoslow's Avatar
how much whp does 7psi increase with stock internals?
Old May 17, 2009 | 02:48 PM
TheShodan's Avatar
Moderator
it depends upon the turbocharger used. the same amount of pressure used from one turbocharger gives a different amount of power than the power given by a different turbo by the same pressure amount. 7psi on stock internals could be 500whp from a GT42, or 250whp from a 50 trim.
Get away from XS power NOW!!!!! Start looking at the stickied FAQs at the top of the forum page. You've got a LOT of understanding to do before you start purchasing. You can also AIM me with questions and information. check my profile.
You've got a lot of work ahead of you.
Old May 17, 2009 | 03:22 PM
nonvtecD's Avatar
Wow, class of 2009. You guys are being really gentle. Why isn't SEARCH highlighted in red anymore?
Old May 20, 2009 | 05:35 PM
notsoslow's Avatar
what is the worst that can happen on a healty motor running 5-10psi?
Old May 20, 2009 | 06:29 PM
jdm inc's Avatar
check this site out there are lots of diff brands.
http://www.turbo-kits.com/integra_turbo_kits.html
Raymond94
Feb 27, 2012 09:03 AM
vtec99ej
Jan 30, 2007 06:53 AM
aaroboost
Feb 9, 2006 08:43 AM
..::91TEG-G2::..
Feb 2, 2004 01:01 PM
ptsiu
Oct 15, 2003 07:18 PM
