Problems with car start up
Old May 17, 2009 | 06:57 PM
stockb18c's Avatar
Default Problems with car start up
just got the car fired up its a fully built b16 with crane stage 2 cams with a stock fpr and 750cc rc injectors high impedence...but after i start it can turn it off i cant get it to fire back up and it floods its self.. so i have to let it set or pull plugs and crank her over...any ideas why this would be and im tuned on crome...
Old May 17, 2009 | 07:44 PM
IN VTEC's Avatar
Default Re: Problems with car start up
cam timing or injector sizing would be my initial guesses. Try it with a set of stock injectors first.
Old May 18, 2009 | 08:08 PM
stockb18c's Avatar
well i do have crane stage two turbo cams set at 0...the intake opens at 2 degrees and exhuast closes at 2 degrees..so i dont know to advance the intake or retard i need tips on the cams
Old May 18, 2009 | 08:12 PM
stockb18c's Avatar
here was it says intake opens at 2.0degrees BTDC and closes at 38.0 degrees ABDC..exhuast opens at 38.0degrees and closes at 2.0degrees ATDC..can anyone help me out on what to put these at
Old May 20, 2009 | 04:56 PM
IN VTEC's Avatar
That's still a really mild cam, even on the big lobe. Cranking enrichment could be too much.
Old May 20, 2009 | 06:55 PM
stockb18c's Avatar
should i be fine to hit vtec and not clip valves
qp
17
Nov 22, 2005 09:25 PM
LSVTEC 91 Civic
Dec 9, 2004 11:19 AM
wangan_DA9
Nov 1, 2004 06:39 PM
0bd1_Kanobe
35
Feb 28, 2004 03:38 PM
92 civic VX B18c
Oct 10, 2003 10:51 AM
