b18c1 b16a3 turbo?
Old May 11, 2009 | 08:39 PM
funkyturkey777's Avatar
New User
Default b18c1 b16a3 turbo?
I have a 4 door teg with a poor mans type r, all the interals are stock and i was wondering if boosting it would be a bad idea. Everyone Ive talked to and all the fourms Ive read it seems to be 50/50. Just want to see your guys thoughts on the matter. Also the motor was just put together a few months ago and has roughly 6-7k. thanks
Old May 11, 2009 | 09:15 PM
92CivicB16's Avatar
Default Re: b18c1 b16a3 turbo?
it will be fine. search some and you will see you can do alot with these motors. get a good tune though
Old May 11, 2009 | 09:41 PM
Schister66's Avatar
Man U FTW
I'm not sure what your static compression is, but that may be a limiting factor for your power goals depending on fuel choice. The rule generally is, 300whp on a stock block is fine as long as you get a good tune and use the proper fuel (usually sub 93 oct pump). If your compression is higher, you may have to either run a higher octane fuel or cut back your power goals to something lower than 300whp.
Basically, yes you can do it; however, there are some limiting factors to consider
Old May 12, 2009 | 05:08 AM
New User
yea im getting the compression checked to be safe and im not really going for big power, its my dd. just looking for 250-300hp and ill be happy, also slow motion is doing my tune
Old May 12, 2009 | 05:31 AM
TheShodan's Avatar
Moderator
Slowmotion is ok, I would also speak with Keith over at Pure-Tuning in Toledo. They have been tuning the hondas we have built for over 5 years,(them being in business for 10 years) using both stock engine and built engine specifications. A complete list is available on what is needed to ensure that things are safe.
Schister66 was not talking about the actual compression test (which is still a good idea, but is specifically referring to the actual static compression of the build is. that is important in terms of fuel use. I ALWAYS recommend 93 octane if possible. You're in Ohio, so you have a lot of options.
PM me with questions regarding turbocharger build, budget, materials and ideas. The one thing you don't want to do is commit to power levels and desires of other people that may not be thinking of YOUR needs.
For example, Many shops and planners look at a car and go, "oh, you want a 35R. Done.!!" when you have no idea if that is the TYPE of power that you're looking for, that may be extremely over budget and just too big for what you're looking for. Doing the right build is like a psychiatry session; we as specialists want to know about you and your needs before giving any true recommendations for your build. This saves you time, money (to make sure you get the good parts), and you actually get what you want
Old May 13, 2009 | 03:03 PM
New User
yea thanks man ill deff check them out, slow motion is pricey and some of my buddys has had probelms with them in the past. im just looking for around 250-300hp. i got a kit off ebay its ur basic 50 trim kit. i was thinking just running 8lbs and i should be fine, lol i got my cbr 929 to go fast o also if anyone knows roughly how much power a c1 block with a b16 head makes let me know my friend is trying to tell me im making 170 already and i think thats WAY to high. thanks
Old May 13, 2009 | 03:21 PM
malink's Avatar
I like it stock
I have faith in Jesus and in my tuner.
wantboost
Apr 27, 2013 11:34 PM
ej1bseries
Sep 21, 2011 03:46 AM
00SIBLACK
Jun 29, 2010 03:27 PM
jdm as fk
12
Nov 10, 2009 09:53 AM
91EagleTalon
Nov 7, 2005 02:43 PM
