postive ignition coil
Old May 11, 2009 | 01:47 PM
gsr-rip's Avatar
New User
Default postive ignition coil
alright well i think my car (94 civic dx) has a bad ignition switch. So i was going to run a positive feed from the battery to ignition coil but where is the ignition coil located? 94 civic dx coupe 5 speed.
Old May 11, 2009 | 04:21 PM
fcm's Avatar
fcm
Old Fart
Default Re: postive ignition coil
The ign. coil is in the distributor, the black/yellow going to the distributor is the ign. input.
Does the cluster "light up" when you turn on the ign.?
Can you hear the fuel pump turn on for a few sec. when you first turn on the ign. switch to run, [not start]?
Does the CEL turn on for a few sec. and then turn off when you first turn on the ign. switch to run?
If the answer is yes to the above, then the ign. output from ign. switch is working.
Do you have a multimeter or test light? 94
boostdvic
46
Jul 29, 2019 12:46 PM
team 15
Mar 7, 2011 12:54 PM
tiredofworkinonit
Feb 25, 2007 04:17 PM
wood 1
Jan 31, 2007 12:19 PM
neilstaH22
Nov 2, 2006 04:05 PM
