90-91 & 92-93 clutch & pressure plate question
Old May 9, 2009 | 03:05 PM
88LXi68's Avatar
Default 90-91 & 92-93 clutch & pressure plate question
so I was running a 90-91 LS trans with ACT clutch and pressure plate. I bought a 92-93 trans, swapped in ITR guts and bought a 92-93 clutchmasters stage3 disc because of the bigger splines. I was going to reuse my ACT pressure plate.
Well, when I when to bolt the pressure plate to the flywheel, the pressure plate would not clear the disc. it was rubbing on the hub portion
I cross referenced ACT's site and they do list a different part # for the pressure plates on a 90-91 and 92-93.
I guess what I am asking is...will a 90-91 pressure plate not work with a 92-93 disc or is it just that a ACT pressure plate not work with the Clutchmasters disc?
ALSO...if I need to get a whole 92-93 kit, are competition clutches any good? I haven't seen any concrete evidence one way or the other.
thanks
Old May 9, 2009 | 09:53 PM
88LXi68's Avatar
Default Re: 90-91 & 92-93 clutch & pressure plate question
Bump
Old May 10, 2009 | 11:22 AM
88LXi68's Avatar
anyone?
Old May 10, 2009 | 07:34 PM
redflaredcrx90's Avatar
all the b series pressure plate are the same all that changes is the disc .90-91 discs are the same 92-01 are all the same disc
Old May 10, 2009 | 08:08 PM
88LXi68's Avatar
so this is probably a difference in design by the 2 brands...great way to find out
vti2
Jan 3, 2007 03:49 AM
boostedsc61
Aug 24, 2006 12:43 PM
91integraLSVTEC
May 25, 2005 11:49 AM
