Car is running Like CRAP! HELP
Old May 9, 2009 | 10:22 AM
StreetRacinThug's Avatar
Default Car is running Like CRAP! HELP
So I recieved a call from a friend explaining his died yesterday and I went to help.
Long story short I realized the car was driving fine from one minute to the next on the highway and the car suddenly died loss of horsepower dramatically.
Arriving I noticed when starting the car it hesitates to start like it doesnt want to fire up while turning over. Once given gas the car fires up and is missing like all cylinders. When the throttle is released the car dies on its own.
Variables:
~Friend explained the day before yesterday he had a hard downshift. Drove the car easy then and yesterday and then suddenly dies.
~He washed the motor 3 weeks ago
~He hasnt changed oil in about 3 months
~Water Pump and Timing Belt where changed a month ago
My Inspection:
CEL: None Yesterday, today when checked the CEL is solid with the two pin connecter.
I found plugs fouled out and went ahead and replaced them.
I checked for spark in every cylinder which it has and its orangish.
Firing Order is on point 1234 34
12
I removed valve cover and set flywheel at TDC little circle in between two lines and the camshafts line up perfectly the left camshaft is a hair under the the right when the arrows are up. Its not even a mm apart very close.
Timing belt is nice and tight
I thought the tune was messed up so I found another ECU with a H22 tune and still nothing
I then started with power checking the injectors every injector has signal from the ecu. I figuired maybe the injectors had became clogged so I went home and snagged another set of OEM H22A4 Injectors gave them a nice clean installed them, turned over and with throttle and shuts down.
Got the car home today hoping that by changing the oil I would find metal specs in the oil to give me relief to say that the motor threw a rod with a spun bearing and I am not and idiot lol. But nothing oil was nice and clean just darker than usual. Where sitting here with no ideas and like I said today the car CEL was checked and it stays solid what the hell does that mean?
Setup is
96 EK OBD2A
JDM H22A OBD1
Dizzy is Internal Coil
JDM Header
Hacked up exhaust
Tuned on Neptunes By Sal in Glen Burnie
Oh by the way to make things even better last night the car sat out and was broken into with a smashed window, flip out dvd with navi was stolen and amps where taken with sub box. YAY Got to love the midalantic.
Old May 9, 2009 | 01:47 PM
Hawkze_2.3's Avatar
Default Re: Car is running Like CRAP! HELP
Do a compression test and post up the numbers...
Old May 9, 2009 | 03:19 PM
All-Motor-Junkie's Avatar
That sounds like your prob right there, weak spark, chec out plugs/wires/cap/rotor in dizzy. go from there. compression never hurts though to see how your motor stands :D good luck!
Old May 9, 2009 | 08:32 PM
prelude208's Avatar
sounds like an ecu problem chud
Old May 9, 2009 | 08:37 PM
Compression check will be done tomorrow yeah, I understand orange is weak, it supposed to be whitish blue for a strong spark. I tried 3 ECU's P13, P72 with H22A setup and P28 with H22 setup one neptunes and one Hondata S100
Old May 9, 2009 | 09:24 PM
if compression is normal fix your weak spark, if that DOESN'T fix your problem, go on from there.
Tzarinque
Sep 22, 2016 11:40 AM
StreetRacinThug
May 11, 2009 06:34 PM
Civicman86
Apr 18, 2006 07:16 AM
HaTa
Mar 27, 2006 03:22 PM
