Turbo b16 questions
Old May 8, 2009 | 09:43 AM
em1_civicsi's Avatar
Default Turbo b16 questions
B16a on 8 pounds
This is the Kit Im building:
-Blox log manifold
-Garret t3/t4 Turbo
-2.5inch downpipe into 2.5 inch exhaust
-Tial 38mm wastegate
-2.5 inch Intercooler piping/intercooler
-Tial bov
-Oil Line/Fitting/all hardware for install
-Walbro 255lph Fuel Pump
-Injectors 550cc
-Golden eagle vacuum manifold
-Colder spark plugs
-Dyno tune
-Air/fuel guage
-Boost gauge
-Oil pressure gauge
-AEM wideband
-New exedy oem replacement clutch with 7 pound flywheel
-ARP head studs
-HKS Universal VBC Manual Boost Controller
Now heres my questions:
What am I missing from the kit to go boost?
What else would you suggest me running?
Also can I use stock srt4?
Can I run 400cc or what do I need?
Do I need adjustable camgears?
Do I need a fuel rail/fuel pressure regulator?
Do I need to run a wideband/02 sensor and WHY?
IS THERE ANYTHING IM MISSING THAT I NEED? lol
Do I need a better clutch then exedy oem?
Thanks everybody and IM SEARCHING this stuff btw I just wanted to have this so people can help me a little more
Old May 8, 2009 | 09:52 AM
Ls_dx's Avatar
Default Re: Turbo b16 questions
Originally Posted by em1_civicsi
What am I missing from the kit to go boost? ARP HEAD STUDS
What else would you suggest me running?ITR CAMS
What size injectors? also can I use stock srt4?600ISH, IDK ABOUT SRT4'S...
Do I need adjustable camgears?NO
Do I need a fuel rail/fuel pressure regulator?YES
Do I need to run a wideband/02 sensor?YES
IS THERE ANYTHING IM MISSING THAT I NEED? lol HEAVIER CLUTCH?
Old May 8, 2009 | 09:54 AM
redlinetuning's Avatar
What are you HP goals? What EMS are you going to use? AEM, Crome, Hondata, etc?
you are upgrading fuel pump and not fuel rail, fpr, or injectors? Why?
550cc injectors would do if you're only running 8lbs. You may want a manual boost controller in the future.
Old May 8, 2009 | 09:57 AM
dephtone's Avatar
Well first off what are you looking for powerwise? This will help determine how big injectors you will need. Also make sure when you buy your parts you leave yourself some room to up the boost.
My recommendations:
New clutch and flywheel to with stand the increased power n torque.
ARP headstuds.
GSR/ITR Cams for added umph.
Most people run DSM 450's if you are on a budget for injectors. I'd recommend 550cc +
Your stock fuel rail and Fuel pressure regulator will be fine till up ~500-600 whp IIRC
I feel that a wideband is necessary, but I am completely **** about monitoring my car to ensure its reliability.
I would also recommend you either run a 2.5" Downpipe or a full 3" exhaust, you are bottlenecking your exhaust which will result in a loss of power.
Old May 8, 2009 | 09:59 AM
Head studs Ill look into those sounds good
I dont want to buy oem cams
like 6c 600cc should be fine or can I go less? also srt?
so i really do need a wideband like aem? or ?
what clutch should I run? its a DD
Old May 8, 2009 | 10:07 AM
Power I want low 13's and if I break 12's ill be happy
I DD my car so I dont need nothing to crazy
and I was thinking chrome or neptune or hondata I was going to have locash racing tune my car in arizona i was going to see what he suggested
I know I have to up grade fuel pump/injectors but wasnt sure about the fuelrail/fpr and I dont know the size of injectors to run.
so 550s would be fine?
My recommendations:
ARP headstuds.
GSR/ITR Cams for added uhmp.
I dont wanna run dsm because of the resister box I rather not have to wire in a resister box but 550cc is good for 8 pounds?
then yeah ill run a 2.5 down dipe then because right now I have 2.5 straight pipe on my car
so a aem wideband be good?
and I dont need a fuelrail/fpr?
ill add arp headstuds to my list
Old May 8, 2009 | 10:14 AM
Updated my Turbo kit/Questions
Old May 8, 2009 | 10:15 AM
It's a good idea to upgrade the FPR and rail, you'll have less bottlenecks. I don't remember if it's low or high impedence for saturated injectors, but you won't want peak/hold if you're not running the resistor box. Yes, 550 should be fine. Just be sure to keep an eye on the injector duty cycles when tuning. wideband is fine, but if you're not intending to do your own datalogging, you won't need it.
clutch, depending on your hp/torque goals, you'll want to buy the appropriate clutch pressure plate. Flywheel, stock will be fine.
What are the specs for SRT4 injectors?
Old May 8, 2009 | 10:19 AM
Yeah I dont want a resistor box I was told bad stuff about running dsm
which type of injectors do I need?
Also can I run SRT4?
so I dont need a wideband?
Im going to have a air/fuel/boost/oil pressure gauges
to make sure my car is working correctly
Old May 8, 2009 | 10:25 AM
dude you're confusing me with your "SRT4" questions. I don't know anyone who is running those in Hondas. Just get RC, Injector Clinic, or Bosch.. there many others.
What "bad" stuff have you heard about running DSM injectors? They're fine actually.
maybe you should research on what each item is and what its purpose is? Seems like you're asking random questions and going off on rumors rather than facts about parts. It does you no good to have guages but not understand what the readouts mean.
Old May 8, 2009 | 10:35 AM
The whole srt4 thing is I find ALOT of srt4 injectors forsale for a reasonable price and there flow is good and isnt honda stock psi for fuel 43 or 48?
well my buddy ran dsm and they messed up alot or it was him lol
plus I rather run high impedance injectors so its more of a plug and play thing.
as for gauges I was told
air/fuel so I know if im running lean/rich etc.
boost so i know if it creeps up to high or to low
and oil pressure well oil lol
Old May 8, 2009 | 10:45 AM
I know nothing about the SRT4 injectors so i'll leave that out. I wouldn't rule it out, but to play safe, get something else. RC injectors can be had for cheap as well.
you buddy probably wired them incorrectly, bad injector, i don't know. If done right, they're fine.
oil pressue guage will help you if you have oil pressure drops, keep your turbo and engine from starving of oil, and, help you monitor your oil pump's performance, maybe an oil leak, etc. There's more to it than what you think.
Old May 8, 2009 | 10:49 AM
yeah, in the area I live I hardly see rc for sale but alot of srt4 roll around and upgrade so there stock parts are always forsale.
and as for my buddy yes that could be true
and thanks about the oil gauge info
Old May 8, 2009 | 10:52 AM
Ls_dx's Avatar
You dont want to "buy OEM cams"? ... umm ok.. well thats the easiest and cheapest HP you can add to your setup.. but hey what do we know
Old May 8, 2009 | 11:00 AM
oh.. you won't need an "air/fuel ratio gauge" if you're getting an AEM wideband. just a thought.
You'll lose some rotational momentum with that 7lb flywheel too.
stock cams and gears will be fine for what you're running.
Old May 8, 2009 | 11:03 AM
I really didnt want to switch cams or anything like that. more of a
buy all my turbo stuff bolt it on get towed to get tuned and drive home
I rather boost my b16a stock. Im only looking to get into low 13's on 8 pounds in my em1 If I dont hit low 13's or If I feel the need to go faster
Ill buy ctr or stage 2 blox cams with valvetrain upgrade.
Old May 8, 2009 | 11:05 AM
Thank you for all your info,
so should I run a stock resurface flywheel or a little heavier one?
Old May 8, 2009 | 11:45 AM
Ls_dx's Avatar
Sweet. pics of Em1...
Old May 8, 2009 | 11:48 AM
Ls_dx's Avatar
I always have ran a stock re surfaced honda flywheel.
Old May 8, 2009 | 12:01 PM
sorry no can do, I dont like posting pictures of it not yet still needs a few things
cool Ill prob do that it saves me a little money lol
Old May 14, 2009 | 09:31 AM
update
-Blox log manifold
-Garret t3/t4 Turbo
-Tial bov
-Injectors rc 550cc
-ngk spark plugs
-street tune
-ARP head studs
boosting 8 pounds street tune on crome
car feels fast yet sluggish
Old May 14, 2009 | 11:51 AM
feeling fast is all relative. fast to you may be different for someone else. Sluggish? get on the dyno for a real tune.
Old May 14, 2009 | 03:08 PM
when in boost/vtec it feels like im going up hill
so sluggish car is fast but feels like im driving up hill when im not
iwantboost690
Jan 12, 2006 10:42 AM
hot93honda
Feb 18, 2005 01:28 PM
civproject14
13
Nov 14, 2004 07:29 AM
