Overheating issue
i got a b18c1, the lower radiator hose is cold while the car overheats and the upper radiator hose is hot, but not too hot to touch, i figured it was the thermostat but i replaced that and it still overheats, any ideas? thanks
some coolants will gel if you mix different types. you didn't put any orange gm coolant in your car did you? i agree your radiator might be full of poo and not working properly.
Also, you could simply have air bubbles in your system. A small amount of air trapped in there can stop coolant flow completely.
Before you changed the thermostat, was the cooling system opened up for any reason, like did you disconnect a hose or something?
air bubbles would cause a fluctuation of the temperature gauge. Meaning it'll jump up and down as air and coolant passes through the hoses and cooling the engine. Air is hotter than the water causing temp to jump and ****. unless you got all air it won't be steady.
since u already changed your thermostat....you should i guess check that radiator.
It sounds like the mechanical thermostat, the one in the block at the lower radiator hose has failed in the close position.
Since the OP apparently has not opened the system (before his problem and changing the thermostat), then yes, it could very well be the radiator.
and at least you came back and told us what fixed it. It's helpful for future people when (if) they do a search.
