Busted piston rings
Old Aug 17, 2002 | 02:01 PM
Dodger2940's Avatar
Default Busted piston rings
Can someone please tell me the simptoms of a busted piston ring?
Old Aug 17, 2002 | 02:04 PM
kwil666's Avatar
Default Re: Busted piston rings (Dodger2940)
blowing smoke do a compression test and a leak down test it will tell you.
keith
Old Aug 17, 2002 | 02:05 PM
Chiovnidca's Avatar
Low compression. May smoke or use oil. Why do you ask?
Dodger2940's Avatar
Default Re: Busted piston rings (kwil666)
What about burning oil? My car is burning oil.
[Modified by Dodger2940, 11:06 PM 8/17/2002]
Old Aug 17, 2002 | 06:23 PM
Dodger2940's Avatar
Any more info?
Old Aug 17, 2002 | 10:37 PM
vtectuner99's Avatar
if your car is burning oil and it is smoking your ring are done, also could be a bad valve seat ,are you turbo are nitrous those are a good stock motor destroyers
Old Aug 17, 2002 | 10:38 PM
ANB Clothing Co's Avatar
you will feel power loss....compression test is key to telling if there are blown rings...usually a white smoke will come out too....but dont just rely on the smoke....it could be from valve seals, headgasket...lots of stuff, so do a compression test, it takes 5 minutes and it will tell you....depending on what compression your running you will be able to tell if you have a blown cylander...
Old Aug 18, 2002 | 01:06 AM
Dodger2940's Avatar
Default Re: Busted piston rings (ProjectSpoon)
Thanks guys My motor is pretty much stock so I am going to do the compression test.
Destructive-
Aug 21, 2009 08:24 PM
J Rob
Sep 1, 2007 07:47 PM
silverboost
Nov 8, 2005 01:01 PM
xlusiveracer
Sep 7, 2005 04:13 PM
Witty
Jul 3, 2003 06:20 PM
