Engine shifting rough
Old May 7, 2009 | 11:43 AM
Yellow96's Avatar
New User
Default Engine shifting rough
I just bought a daily driver integra about 2 days ago and im afraid i might have found why it sold cheap or maybe im just paranoid. Anyways when the car shifts (automatic) it seems to be a little rough. Im use to new cars and stick shift so i may just be trippin but it seems to be more notciable when i drive slow it seems to jark into the next gear. When i drive fast it all seems to shift smooth. Just the way it is or tranny problem? Anything i can check on my own to tell?
Old May 7, 2009 | 05:59 PM
Yellow96's Avatar
New User
Default Re: Engine shifting rough
Old May 7, 2009 | 07:31 PM
Yellow96's Avatar
New User
anybody?
Old May 7, 2009 | 07:34 PM
MD426's Avatar
If I'm going very slow and it shifts it will shift a little hard because the RPM will drop hard with little acceleration. Try flushing out the transmission fluid a few times to see if it smooths it out.
Old May 7, 2009 | 07:43 PM
dapek's Avatar
Why would he flush the transmission out a few times? Besides the costly-ness of purchasing transmission fluid, you would only need to do it once.
Go ahead and purchase three quarts of Honda ATF and, assuming you have a B series, you will be using 2.5 quarts of it. This may help you out..or you could just go manual
Old May 7, 2009 | 07:45 PM
Yellow96's Avatar
New User
Ill def do the tranny fluid this weekend.
Old May 7, 2009 | 07:48 PM
dapek's Avatar
Haha just kidding around man, it's your daily and it's YOUR car so keep the auto unless you find that it's toast.
Old May 7, 2009 | 07:49 PM
MD426's Avatar
Flush it with Wal-Mart ATF frist then use the good stuff. Anything is better than worn out ATF.
Old May 7, 2009 | 08:26 PM
produca2's Avatar
BTW your engine doesnt shift.....just FYI
Old May 7, 2009 | 08:54 PM
Yellow96's Avatar
New User
if its not shifting into the next gear what is it doing then?
Old May 7, 2009 | 09:00 PM
MD426's Avatar
The engine is just varying from RPM to RPM, the transmission is shifting.
Old May 7, 2009 | 09:21 PM
produca2's Avatar
yes yes (cheese and rice!lol)
Old May 8, 2009 | 12:35 AM
rjHella's Avatar
shift that **** yourself
natedawg173
Honda CR-V & Element
Dec 16, 2014 09:40 AM
playlife
Aug 22, 2011 10:58 AM
Tyson
Honda S2000
Apr 15, 2006 12:10 AM
sohc prelude
Feb 26, 2006 07:26 PM
