ABS are not working
Old Aug 17, 2002 | 07:58 AM
VTI_VTEC's Avatar
Default ABS are not working
Can somebody help me with a problem that i have on a my 93 civic vti saloon (eg9). driving along today and ABS light came on ,so checked the service plug and it show me there is a problem with the front right speed sensor. (code 4 / 1).
Can somebody tell how to change the speed sensor ?
Cheer kenny
Old Aug 17, 2002 | 10:08 AM
Chiovnidca's Avatar
Default Re: ABS are not working (VTI_V-TECH)
It's pretty simple. You may want to check the resistance of it to make sure it is the problem. Maybe someone will post the spec, I don't have it here. Throwing parts at a car to fix a problem can get expensive.
Old Aug 17, 2002 | 11:24 AM
VTI_VTEC's Avatar
Default Re: ABS are not working (Chiovnidca)
can you please tell how to check the resistance and how do i get into the speed sensor to do this?
Cheer kenny
Old Aug 17, 2002 | 11:30 AM
Chiovnidca's Avatar
Disconnect the connector and measure the resistance between the two wires with an ohm meter.
Old Aug 17, 2002 | 12:11 PM
VTI_VTEC's Avatar
Disconnect the connector and measure the resistance between the two wires with an ohm meter.[/QUOTE]
where about do your dissconnect the speed sensor form ,is it behind the the disc and did it only two wire going to the sensor.
Cheer Kenny
Old Aug 17, 2002 | 12:20 PM
slowerthanu's Avatar
New User
All your base are belong to us.
Old Aug 17, 2002 | 01:35 PM
deepnite's Avatar
Default Re: ABS are not working (slowerthanu)
dont know about checking the resistance..but mine went on and the fuse blew
Old Aug 17, 2002 | 02:40 PM
VTI_VTEC's Avatar
Has anybody got any pictures of the speed sensor ,so i can see what i am looking for.
cheer kenny
Old Aug 17, 2002 | 03:03 PM
Chiovnidca's Avatar
The sensor bolts to the knuckle. Follow the wire up the knukle and through a grommet into the engine bay. Keep following it until you get to the orange connector. That's where you check the resistance.
Old Aug 17, 2002 | 03:50 PM
VTI_VTEC's Avatar
Thank will try that tomorrow
Kenny
Old Aug 18, 2002 | 01:56 AM
VTI_VTEC's Avatar
[QUOTE]
<U></U>
The sensor bolts to the knuckle. Follow the wire up the knukle and through a grommet into the engine bay. Keep following it until you get to the orange connector. That's where you check the resistance. <U></U>
I have check the resistance and it was 26 M ohm and the one that is working is about .733K Ohm . can somebody please post what is the correct resistance of a working front right speed sensor
Cheer Kenny
Old Aug 18, 2002 | 05:50 AM
Chiovnidca's Avatar
26 million ohms is way too much, replace it.
Old Aug 19, 2002 | 08:02 AM
VTI_VTEC's Avatar
Sh*t got a price for 1 speed sensor for my car £124+vat (that what i get for only a EG9 )
kenny
96teggynonVtec
Jan 23, 2007 01:32 PM
IntegraLs94Cam
Mar 29, 2005 05:24 PM
rusureboutdat
Sep 2, 2004 05:28 AM
90da4dr
Aug 4, 2003 08:03 PM
prelude_scotland
Apr 24, 2003 07:16 AM
