Problem with my LF ABS sensor :(
Old Mar 26, 2005 | 04:20 PM
IntegraLs94Cam's Avatar
Default Problem with my LR ABS sensor :(
Sorry i did not Mean my Left Front wheel ... I ment to say my LEFT REAR sensor!!!
Anyways....
Well for a long time my ABS light has been on. I pulled the code and the code was for my left ABS sensor.... But for the past 2 months the light went away and my ABS was working. I was like hell ya it fixed it's self but last night it rained hard and my ABS light has came back ... I called Acura and asked how much it would cost to get a new ABS sensor and the labor... They told me almost 300 dollars ... I WAS LIKE WTF!!!!!!! i am wondering how can i change it myself... Is it just a sensor that plugs right in???? Where is it at so i can change it ??? has anyone done this before is it hard?? Or should i just let Acura fix it
Old Mar 26, 2005 | 05:09 PM
Lord Helmet's Avatar
Default Re: Problem with my LR ABS sensor :( (IntegraLs94Cam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLs94Cam &raquo;</TD></TR><TR><TD CLASS="quote">
Anyways....
i am wondering how can i change it myself... Is it just a sensor that plugs right in???? Where is it at so i can change it ??? has anyone done this before is it hard?? Or should i just let Acura fix it </TD></TR></TABLE>
Don't buy it from the stealership. Buy it from a local honda/acura junkyard or online junkyard website. It's very easy to identify because it is the only wire going to the wheel hub assembly. Just unplug the wire and unbolt the sensor from the wheel hub assembly and you're done. It takes me 2-3 mins max for both sides.
Old Mar 26, 2005 | 05:25 PM
Default Re: Problem with my LR ABS sensor :( (sleeperciv)
where is it located ?? behind the rotor???
Old Mar 26, 2005 | 06:00 PM
natesgarage's Avatar
Yea. I's actually attached to the hub where the control arm comes in. I believe the bolt is a 12mm
Old Mar 26, 2005 | 06:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLs94Cam &raquo;</TD></TR><TR><TD CLASS="quote">where is it located ?? behind the rotor???</TD></TR></TABLE>
yes it's behind the rotor. can't miss it.
Old Mar 27, 2005 | 04:31 PM
will i have to take off my rotor to fix it or can i jack up the car , take the wheel off and get under it and unbolt it and replace it with a new one..
Old Mar 29, 2005 | 11:28 AM
hey can someone host some pics for me .. because i can not find it .. im going to take a pic of under the car and see if someonme can point it out to me
Old Mar 29, 2005 | 05:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLs94Cam &raquo;</TD></TR><TR><TD CLASS="quote">hey can someone host some pics for me .. because i can not find it .. im going to take a pic of under the car and see if someonme can point it out to me </TD></TR></TABLE>
Dude it can't be that hard. It is the "ONLY" wire going to the wheel assembly, the "ONLY" "electrical" wire going to the wheel assembly. Don't make it harder then it needs to be.
Old Mar 29, 2005 | 05:10 PM
a;right sorry .. i think i know where it is .. it is hooked up to the capiler .. a big black wire
Old Mar 29, 2005 | 05:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLs94Cam &raquo;</TD></TR><TR><TD CLASS="quote">a;right sorry .. i think i know where it is .. it is hooked up to the capiler .. a big black wire</TD></TR></TABLE>
yes
tobytigger
Jun 23, 2015 04:31 PM
wrinkly
Jun 8, 2007 07:12 AM
rollercosta123
Nov 25, 2005 12:09 AM
TerribleOne
Mar 19, 2003 10:59 AM
Dirt
May 22, 2002 12:38 PM
