help in b16a swap
Old May 5, 2009 | 10:28 AM
oneEg1Tc's Avatar
Default help in b16a swap
I just did my swap into my 93 cx hatch. With a 0bd1 harness and we had to do the drirect wires for the vtec and now my check engine lIght comes out with a 23 cel the guy that I bought the engine from said everythin was ok in his car and doesn't. Know why that. Cel came out. So my question is .. what could be the problem and its that the correct harness ? I have a b16a ecu p30 on it as well .. any help?
Old May 5, 2009 | 10:37 AM
MonkeyMagic's Avatar
Default Re: help in b16a swap
you forgot to wire up the knock sensor
robbys89's Avatar
you gotta wire up your knock sensor like you did with the vtec. cel 23= knock sensor. it goes to pin 3 on connector D if i remember correctly. the wire from the knock sensor is red and blue(1wire) so look for that on the engine loom that isent leading from the cars loom so do what you did wit vtec
Old May 5, 2009 | 12:01 PM
oneEg1Tc's Avatar
I thought the swap was just to plug and. Play kinda with the obd1 harness. But. I guess ill have to run the knock sensor cable
Old May 5, 2009 | 12:05 PM
robbys89's Avatar
well like the vtec the knock sensor dosent lead strate to the ecu cause cx engines dont have them + id advise you not too blitz the car around till you wire that sensor up. your pistons will come out through the walls
Old May 5, 2009 | 12:17 PM
oneEg1Tc's Avatar
Ooook didn't know that could happen to the pistons and now cel 1 came. Out ughhhhh
Old May 5, 2009 | 01:05 PM
Ya Digg's Avatar
And why would that happen?
Anyway wire up knock sensor or get a chipped p28 with a b16a map on it. It wont blow your engine if its not wired up but I think it retards your ignition timing. making it slower.
Ya Digg's Avatar
I think number 1 is the o2 sonsor.
Old May 5, 2009 | 01:24 PM
yup
he's swapped the car using the cx harness.. needs to convert to 4 wire
cx= one wire o2s
dx/lx/si/sir/ex everything under the sun = 4 wire o2s
hx/vx = 5 wire o2s
Old May 5, 2009 | 06:47 PM
Laz's EP's Avatar
Originally Posted by MonkeyMagic
yup
cx= one wire o2s
hx/vx = 5 wire o2s
How do you convert?????
Old May 5, 2009 | 08:05 PM
Ya Digg's Avatar
you could use an integra Harness and it will connect right to your shock tower harness with the 4 wire o2 wired in or you can wire the other 3 wires but I don't know where exactly they go
Old May 6, 2009 | 09:10 AM
Laz's EP's Avatar
So we would need to change the engine harness?
Old May 6, 2009 | 09:12 AM
Ya Digg's Avatar
just run the 3 wires for the o2 that the CX harness doesnt have OR get a integra harness that has it wired in and can connect to your shock towers.
Add 3 wires cheap but IDK exactly where they go
Integra harness is easy, no wiring at all but would have to pay more.
Old May 8, 2009 | 11:18 AM
oneEg1Tc's Avatar
So I. Was doing some research. And I. Find people saying that a 94 gsr harness its the best choice for a b16a swap on to. A 93 cx hatch how tru its that ?
Old May 9, 2009 | 05:35 AM
Laz's EP's Avatar
The harness has the 4 02 sensor cables, and CX has only one.
Old May 10, 2009 | 08:58 PM
Ya Digg's Avatar
From what I read on FF-squad ALL civic harness' are wired for 4 wire o2 from shock tower to ECU but NOT all like CX and VX are wired for it from shock tower to engine.
http://www.ff-squad.com/tech/wiring/...ktowerplug.jpg
so a GSR harness would be best bet as long as its the same OBD.
italian_virus
Aug 9, 2010 07:46 AM
jdm_sai
Jul 18, 2010 06:05 AM
bustah49
May 11, 2007 07:57 AM
stockegsix
May 11, 2003 10:17 PM
devonic
10
Apr 9, 2003 09:53 AM
