Smoke out of valve cover fitting...?
Old May 5, 2009 | 09:33 AM
SurferDude905's Avatar
Default Smoke out of valve cover fitting...?
I hooked up my turbo kit and I'm currently running it off a basemap just so I could go and get a few things done before the tune.
I started to notice that my car is always smoking from under th hood. Today I pulled into my driveway and popped the hood and smoke is coming out of the fitting on the valvecover. I haven't got around to installing my catch can yet so I just put a filter on the valve cover...
Is this normal?
Old May 5, 2009 | 10:29 AM
turbo-crx's Avatar
Default Re: Smoke out of valve cover fitting...?
usually means you have blow by.
Old May 5, 2009 | 11:02 AM
b20beast83's Avatar
might be cracked ring lands
how much smoke?
Old May 5, 2009 | 12:16 PM
Not an exsessive amount but enough to just come out from under the hood and then dissapear. Is that what catch cans are for? I dont know if the ring is cracked, car still runs good.
Blow by is due to the pcv?
Old May 5, 2009 | 11:27 PM
FRANKBUILT's Avatar
Do compression check there SHOULD NOT BE SMOKE COMING OUT OF THE VALVE COVER!, sounds to me like you may have cracked a ringgland on the piston, very easy to do if you were boosting smashing on your car with it UN TUNED. Is base timing set?
1slowdc2
Apr 24, 2006 08:23 AM
Ls-Turbo
Dec 11, 2005 10:30 AM
Ls-Turbo
Dec 11, 2005 10:28 AM
tnsxsear1
Nov 20, 2003 07:08 PM
