Lsv-t motor build suggestion on rods and pistons?
Old May 4, 2009 | 07:37 PM
Frost7177's Avatar
Default Lsv-t motor build suggestion on rods and pistons?
Im looking to go as high as i can go with pump gas. The bottom end is a b18b1 out of a 97 integra and the head is a jdm b16 head with a skunk 2 im and 70 mm throttle body. My question is what compression do you guys think i should go ?What brand pistons and rods are good. I have a gt35r turbo. And i topmount manifold with a 3 inch downpipe. Should i sleeve the motor?
Old May 4, 2009 | 08:26 PM
m R g S r's Avatar
Default Re: Lsv-t motor build suggestion on rods and pistons?
If you want as much power as possible on pump gas, do NOT go crazy with the compression. Keep it pretty low.
On pump, say you want around 500whp...for that sleeves are not necessary. But it's up to you for extra insurance, and the possibility of making more power in the future.
Old May 4, 2009 | 09:45 PM
Ls_dx's Avatar
sleeving the motor (for me) is a 2500.00 question....
My current and next motor are stock sleeve/wiseco/eagle/arp....
Old May 5, 2009 | 05:37 AM
djxtreme808's Avatar
Think long term. If you sleeve it you have no limits for the future. If your goal is reachable on stock sleeves, then your good to go. 9.5:1 is good.
Old May 5, 2009 | 11:26 AM
Frost7177's Avatar
Should i leave it stock bore size or should i bore it out +.20" or .40" over keep in mind it will probably be sleeving it since my buddy does it and will be giving me a really good price. If not should i stick to the stock bore? As for the head should i leave it stock since its a jdm b16 head the guy im buying it off of says itll spin till 9500 rpms. Is 9.0:1 good i couldnt find 9.5:1
Old May 5, 2009 | 04:40 PM
Frost7177's Avatar
anyone?
Old May 7, 2009 | 08:12 PM
Frost7177's Avatar
im guessing no more advice
Old May 7, 2009 | 08:27 PM
SilverEk3dr's Avatar
im running an lsv 9.5:1 cp pistons(coated tops & skirts), crower rods, stock sleeves w/golden eagle block guard. Made 550 on the old setup with gt35r. New setup had some issues and is currently at 470@18psi
Old May 8, 2009 | 03:08 AM
the bore can be what you want. I bought a set of 84mm aries pistons cheap so thats what I bored it to. Just remember there is no replacement for displacement.
Old May 8, 2009 | 06:26 AM
redlinetuning's Avatar
I think what you meant was .020", not .2".
.020" = .5mm
So overboring
+.020" = 81.5mm
+.040" = 82.0mm
9.0:1 compression is fine, you won't want to go much lower than that though.
JDM B16 heads will not rev to 9500 unless he's done valvetrain upgrades. Just becuase it's "JDM" doesn't mean it'll do special magic tricks.
I'm running CP 81.5mm 9.0:1 pistons in my b16 block with gsr head. small top mounted turbo spools in at 2500 and peaks out at 300+ at ~1BAR. .053" cometic hg lowers the compression slightly.
notoriousB
Mar 31, 2013 10:19 PM
doug118
Oct 10, 2008 02:42 PM
the.hamburglar
Sep 29, 2005 05:59 AM
anothersickhatch
May 27, 2004 08:55 AM
BSpec24
Jan 16, 2002 01:39 AM
