please help... please have pity
Old May 3, 2009 | 11:25 PM
ohsosikcivic's Avatar
Default please help... please have pity
Hello everyone.
I have a 1997 civic DX and this weekend i put a LS Vtec Turbo in it. Im using a chipped p28 from phearable wtih a jumper harness. The car wont idle. I got the AIC and changed the plug from the civic plug to the one that was on the teg. and used 2 of the 3 wires... i discarded the orange wire. i found a writeup which wires to use and im pretty sure they are correct.
i heard from a friend i might need to move one of the wires im using, over a pin on the ECU
has anyone had any experience with that? any ideas why i might not be idling?
Im From RI. If someone around here tunes and could get my car going i will be willing to compensate you. please help...
first swap and need advice. thanks!
Old May 4, 2009 | 08:42 AM
Default Re: please help... please have pity
bump... please help
Old May 4, 2009 | 09:44 AM
mouab18c1's Avatar
your ecu is plug and play once you have the jumper harness..check for vacuum leaks/ coolant leaks
Old May 4, 2009 | 02:12 PM
i understand that... i had to rewire the aicv for a 2 wire set up insted of a 3 wire.. you think its just vacume leaks?
Old May 4, 2009 | 04:21 PM
mouab18c1's Avatar
it could be..usually your car wouldnt die even if the IACV wasnt plugged just wouldnt idle right. check to see if you hear vacuum leaks. is there any CEL?
Old May 4, 2009 | 04:25 PM
99JDMHATCH's Avatar
how far you from newport
Civicex0
Jan 26, 2018 04:00 AM
93egboosted
Mar 18, 2009 07:27 PM
JDcompman
Aug 1, 2004 06:31 PM
xSpooNxEkx
Jul 13, 2003 02:16 PM
