replaced the starter and car still wont start
Old May 3, 2009 | 08:30 PM
eg_beast's Avatar
New User
Default replaced the starter and car still wont start
ight so i stop my car at the gas station and came back out less than 5 mins and car didnt start tried jumping it and that didnt work . towed it home and replaced the starter with a brand new one and tried jumping it again and it still wont start .... PLEASE GIVE ME UR ADVICE !!!:
Old May 3, 2009 | 08:32 PM
Former User's Avatar
Default Re: replaced the starter and car still wont start
Does the engine crank when you turn the key to ON(III)? If not, check the starter switch at the top of the clutch pedal.
Old May 3, 2009 | 08:45 PM
eg_beast's Avatar
New User
no crank . checked the switch and everything seems to be fine ! could it be and altenator ?
Old May 3, 2009 | 08:50 PM
Do you measure battery voltage at the large black wire attached to the starter?
Do you measure battery voltage at the smaller Blk/Wht wire attached to the starter when the key is turned to ON(III)?
How did you check the switch?
baller status's Avatar
Alternators don't start cars, batteries do. But you should actually TEST the battery before you replace it.
"Diagnosis" doesn't mean throw parts at it.
Old May 3, 2009 | 09:01 PM
laziebun's Avatar
Votmeter is your best friend right now. Does it make any kind of noise when trying to start it? Are you getting any current on the signal wire on the starter? If your getting current to your signal wire and no noise when trying to crank it, i've got money on it to bet it your starter ground wire. Its the wire off your tranny that goes to the body of the car. Take it off and clean the surface and should be good to go.
Old May 3, 2009 | 09:04 PM
TravisCadello's Avatar
Theirs a Little wire on the starter is it connected? Not the Hot wire but the one that tell the starter to turn over when you press the key forward. if its their put a wire from the positive to the starter where the skinny wire went and if it turns the engine over then check your fuses and ignition switch.
Old May 4, 2009 | 02:19 AM
speedfreek128's Avatar
could be your coil died....happened to me on a EF and a DC
Old May 4, 2009 | 04:57 AM
monkey_boi's Avatar
check the battery first
then check the wires to the starter
then check to see if you have spark
then if no spark check the fuse box under the hood that sits not far from the battery
if not that then check in the cabin fuses and also the main relay it could any of these
Eklove2496
May 17, 2014 09:03 PM
gooblinn258
Dec 16, 2013 08:23 AM
Jmx305
12
Dec 9, 2013 03:20 AM
EF9 JAMS!!!
Sep 23, 2004 10:21 AM
curiousgpnoy
Jun 25, 2003 08:43 AM
