question about plug wire placement...read
Old May 3, 2009 | 03:12 PM
B16Civic93's Avatar
Default question about plug wire placement...read
usually on a dohc vtec engine when looking at the distributor it is
34
12
when i put my ls/vtec together a while ago, with the cams in facing up and the mark on the crank facing the mark on the oil pump. after i put the distributor on i noticed that when looking at the distributor it was
21
43
that is where the rotor faced when i put the distributor on the engine. i put the plug wires on accordingly without thinking about it and it started right up, timed the motor and had a street tune on it,
i was just curious if this would make a difference as to how the engine runs, i cant really see that it would make a difference since you time the motor using the first spark plug wire so it is timed correctly. just something i was thinking about when i replaced the distributor on a friends car and saw the wire placement difference. this may sound kind of confusing the way i worded it but if i need to clarify anything let me know.
Old May 3, 2009 | 03:24 PM
seanbev24's Avatar
Default Re: question about plug wire placement...read
After re-reading your post and realizing that your car runs fine, I'm a bit confused. I just didn't think a car would run right like that.
Old May 3, 2009 | 05:10 PM
evo_s_uck's Avatar
ya it doesnt even sound like itd start or run... does it run smootly or rattle
Old May 3, 2009 | 06:06 PM
dtapia's Avatar
what year and model i will send you the correct firing order
Old May 3, 2009 | 06:41 PM
srmofo's Avatar
who cares about your firing order???? I demand MOAR pics of your avatar.......topless!!!
I am also kinda confused what your saying....I can tell you though, if your firing order is off the car will not run smoothly, so you must have it right
Old May 6, 2009 | 02:48 AM
B16Civic93's Avatar
the firing order itself is correct, 1342 but the placement of the wires is 180* out, if you look at how the numbers are shown looking at the cap
ZillaG
Apr 30, 2013 12:54 PM
urtz
Nov 29, 2006 07:28 PM
zc_crx
Jan 4, 2006 04:06 PM
VTcivicEG
Sep 1, 2004 01:13 PM
JSpecwest
Dec 19, 2001 03:57 PM
