Port on top of throttle body, does it need to be plugged?
Old May 3, 2009 | 01:09 PM
a1320honda's Avatar
Default Port on top of throttle body, does it need to be plugged?
So ive had a ton of boosted setups over the years, and never had this plugged, but i was doin some pressure testing and found that this port will allow boost to exit the setup, but its before the throttle plate. My buddies car was running like complete dick and had that capped and we took that off and it ran better for some reason, so should it be plugged or not?
Old May 3, 2009 | 01:33 PM
SilverEk3dr's Avatar
Default Re: Port on top of throttle body, does it need to be plugged?
i welded mine shut..
Old May 3, 2009 | 01:57 PM
Garage 808 Hatch's Avatar
it needs to be plugged, otherwise, under boost, you have a leak, on an NA setup its fine beacuse its before the TB
Old May 3, 2009 | 03:59 PM
Ls_dx's Avatar
heavy rubber vacuum cap with zip tie.
fukenricen
Sep 18, 2009 10:25 AM
Riper1
Jan 30, 2009 07:48 AM
B20luda
Nov 13, 2004 05:03 AM
oldbeefcake
Jun 14, 2003 09:05 AM
