need help,changing some stuff on my setup
Old Sep 17, 2009 | 06:22 PM
fukenricen's Avatar
Default need help,changing some stuff on my setup
ok well after this weekend i noticed the car wasnt hitting its 130plus mph and was only hitting 124mph.
noticed i have alot of boost leaks and i have to change a few things.
my edlebrock throttle body is leaking from both ends one where the sensor is and the other where the throttle cable connects to.
my cooler is done aswell
heres what i need to know,
i have a magnus manifold with a mustang 75mm throttle body.
i was thinking of going with skunk2 throttle body 70mm.
also i have a throttle body that is 86-93mustang 5.0bolt pattern,does anyone know if this skunk2 is the same bolt setup?
http://www.skunk2.com/mm5/merchant.m...de=309-05-0050
Keep in mind i am going with 3" pipe so will a 70mm throttle body vs my 75mm make a difference?
also looking at this cooler ,goal is 650/700hp
http://vibrantperformance.com/catalo...roducts_id=960
thanks in advance for you help since you guys always give me the right advice
Old Sep 18, 2009 | 06:19 AM
fukenricen's Avatar
Default Re: need help,changing some stuff on my setup
anyone?
Old Sep 18, 2009 | 06:27 AM
rota92
Guest
Posts: n/a
Call Skunk2, but I doubt it's the same.
The 5mm difference won't be much, but since you have a nice manifold it's best to optimize that for ya.
Old Sep 18, 2009 | 06:42 AM
2fastGSR's Avatar
King of the One Liners
The skunk2 tb is not the same bolt pattern as the mustang tb
Old Sep 18, 2009 | 09:16 AM
fukenricen's Avatar
Thanks guys..
ok so i called edlebrock up and spoke to tech.
The reason why i was debating on a throttle body was simple because mine i noticed when i hooked up the smoke machine, it would smoke from the sensor side and from the rod side that connects to the throttle cable.
Edelbrock told me its normal because its not a 100percent seal on where the rod goes threw.
Can anyone else confirm this for me?
Old Sep 18, 2009 | 10:17 AM
BoostedJeff's Avatar
I almost lost a motor to an edelbrock 75mm mustang throttle body. Whatever you do, if you get this, take the screws that hold the throttle plate to the shaft and loctite them.
I can't vouch for the throttle body being 100% sealed, but I never had any issues that would be caused by that.
Old Sep 18, 2009 | 10:25 AM
fukenricen's Avatar
wow i heard about that issue with other throttle bodys where bolts went loose.
has anyone done a smoke test on their car and found that it leaks from those ends of the throttle body?
charlie_sohc
Mar 23, 2007 02:58 AM
FATninja19
Jun 26, 2006 10:51 PM
B18cHatch06
Mar 29, 2006 02:53 PM
Spectrum24x
Feb 12, 2006 04:29 AM
