rear disc swap
Old May 1, 2009 | 05:55 PM
t4lude98's Avatar
Default rear disc swap
can i use the swap from a 92 da 4 door for my 97 ek hatch?
Old May 1, 2009 | 07:11 PM
rick_rabies's Avatar
I'm not Rick!
Default Re: rear disc swap
yes
Old May 1, 2009 | 07:13 PM
I'm not Rick!
you have to get the brake cables from a hatch or coupe ek that had disc brakes, your drum cable wont work. while your at it switch out the trailing arm bushings..spray the bolts with lube and let them sit...i didnt and busted 3 bolts with a breaker bar...sux
Old May 1, 2009 | 07:45 PM
t4lude98's Avatar
thanks so it will fit i cant find solid info about the da swap
Old May 1, 2009 | 09:40 PM
V8 Eater's Avatar
you wont notice much of difference dont even bother with all the work and labour.
if anything go for integra rears and fronts along with a 1in m/c only then would you notice a difference!
Old May 2, 2009 | 05:02 PM
t4lude98's Avatar
they are integra rears and i already have ex/si fronts with si prop valve and m/c and booster
Old May 13, 2009 | 03:47 PM
t4lude98's Avatar
are the DA and EK trailing arm bushings the same?
Old May 13, 2009 | 04:45 PM
94EG8's Avatar
Seagull Management
No, if you need to replace the bushings buy them for whatever the trailing arm came from.
Old May 13, 2009 | 05:15 PM
t4lude98's Avatar
but just to be clear the DA rear set up will bolt onto me EK even though the TA bushings are different
and thanks for the response
Old May 13, 2009 | 06:14 PM
turb0integra's Avatar
it will fit just get the parking brake cables
PardonmyEK9
Jul 9, 2010 07:48 AM
sj-performance
Jul 14, 2009 07:55 PM
NathanMorris
Feb 9, 2008 11:59 PM
Eaglekper0046
Feb 7, 2007 09:35 AM
ncVTEC1313
Jun 3, 2004 05:14 PM
