Honda Bond on Valve Cover Gasket?
was reading through some archived posts trying to figure out my vtec solenoid/gasket leak and i saw this.. ive never done put hondabond on the valve cover gasket corners, should i have been?
Is this related to the S2000? If so then no RTV needs to be on the VC gasket.
If you are talking about a B-series motor then yes the FSM says to put it on the corners. You can use any RTV gray though, it doesn't have to be hondabond.
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
do not use it on the VC... it doesnt call for it so then dont do it... I didnt use any on mine when i had my VC powdercoated... just torque correctly and check for any leaks...
rasinhell
Aug 8, 2005 01:00 PM
4crx4me
Jun 8, 2004 03:23 PM
