B16 Head Gasket Help
oem should be fine. the oem gasket uses a tad bit of clearance on the inside diameter of the cylinder walls and .25 isnt all that much.
i used an oem gasket on my oversized pistons.
well first off its .02" or .025" over which will make it 81.5mm bore. not 81.25 bore. therefor you need a 81.5mm gasket. if you had a smaller gasket think about what that will do to the flow...not good.
since ctr pistons only come from japan and are only used in civic type r motors, would'nt you think that they would use the metric system? hence, a .25mm oversized piston would still be .25mm over, not converted to hundredths of an inch like the standard system.
Eghatchgsr8
Sep 19, 2014 02:24 PM
97CTR
14
Jul 18, 2004 01:47 PM
BlackGSR
Feb 26, 2002 06:52 AM
