D17 Crank into D16
Old Apr 29, 2009 | 03:28 PM
NightCat's Avatar
Default D17 Crank into D16
Just wondering if anyone has done it? I'm sure it's not worth the money..but nor is a mini me and people still do that.
Lookin at possibly throwing a D17A6 or A1 crank into my D16Y8. the Bore matches up the same it just has a 4.4mm longer stroke.
Also, anyone heard about putting the 7th Gen GX 12.5:1 pistons in a D16?
Figure you throw the D17 Crank and GX pistons into a Y8...instant race motor lol.
Probably instant catastrophic engine failure too...but it would be fun until it exploded.
Old Apr 29, 2009 | 03:30 PM
jasons9594's Avatar
Default Re: D17 Crank into D16
u would have to use the d17 rods also....
Old Apr 29, 2009 | 03:34 PM
JHP's Avatar
JHP
Ive seen a similar build using an A6 block. It used a D17 Crank and rods, oil pump and oil pan along with other parts. It is possible. Didnt seem like must work it you have the tools to remove some material off the block and what not. It ended up putting out like 160hp and 135 tq.
Old Apr 29, 2009 | 04:02 PM
NightCat's Avatar
I was wonderin if it was sorta like the Spoon S2k Stroker, it uses stock S2k Rods, just has a smaller crank.
Hmm..so you need the D17A6 Crank, Rods, oil pan and pump?
anyone know about the 12.4:1 pistons??
that be sick to have D17 bottom end set up with 12.4:1 pistons in a Y8
Old Apr 29, 2009 | 04:29 PM
JHP's Avatar
JHP
Not sure what it would end up in a Y8 but the A6 ended up with a 13.2:1 CR with the GX pistons.
Old Apr 29, 2009 | 04:30 PM
NightCat's Avatar
dayam...and it only put down 160hp?
Old Apr 29, 2009 | 04:42 PM
JHP's Avatar
JHP
It put down more, 172 HP @ 7600 RPM, but was tuned down for a better torque curve. The 165 HP was at 6900 and the torque was at 5400.
Old Apr 29, 2009 | 04:58 PM
NightCat's Avatar
Damn so it sounds like this set-up has potential.
anyone try it in a Y8? I might wanna do this before I go boost
Mr HYDE
Mar 13, 2004 08:14 PM
BatuKing
Sep 3, 2003 02:16 AM
2K_TEG
Jun 30, 2002 10:15 AM
*Boostwerks*
May 10, 2002 08:05 PM
turbo_ef9
Mar 5, 2002 09:23 AM
