Honeymoon with my EM1 over. P1457 came up
Old Apr 28, 2009 | 08:44 PM
goldenmustache's Avatar
Default Honeymoon with my EM1 over. P1457 came up
On the way to the shop this weekend to see how much its going to cost depending on whats causing the code. I know it could be a number of things including the loose gas cap but that isnt it. How much have you guys spent repairing your p1457 codes?
Old Apr 28, 2009 | 08:56 PM
Arthas's Avatar
Default Re: Honeymoon with my EM1 over. P1457 came up
A very common late 90's code, P1457 is a failure in one of the evap system solenoid valves. There are 2 culprits, the Vent Control Valve & the 2 Way Bypass Valve. They are located under the vehicle, roughly below the left rear seat area. They short out due to corrosion/contamination from water seeping into the valves. I changed both, but the real culprit seems to be the 2 Way bypass Valve.
Old Apr 28, 2009 | 08:59 PM
Its the first time i see it since I own the car, supposively if you neglect it, it can affect the ecu, I don't think its at that point, but ill have to wait and see what the mechanic says.
Old Apr 28, 2009 | 09:12 PM
Arthas's Avatar
**** mechanics.
Just try a new gas cap first.
Old Apr 28, 2009 | 09:38 PM
ChuckNorris's Avatar
lol.. i have the exact same code.
i'm getting a new gas cap tomorrow.
Old Apr 29, 2009 | 05:41 AM
Did you know that while playing scrabble, if you spell Chuck Norris you win.......forever!
Old Apr 29, 2009 | 06:43 AM
SOHC_4dr's Avatar
Chuck Norris is win....BUT WTF does this have to do with anything?
Old Apr 29, 2009 | 07:03 AM
I wasn't sure if Chuck himself knew that
Old Apr 29, 2009 | 08:00 AM
Vindicator9000's Avatar
318 Curves, 11 miles
First off, do your best to not overfill the tank. Mine throws this code 100% of the time that I overfill it. I chased this problem for 2 years and replaced almost everything in the EVAP system, and will still throwing the code. I followed the helm's flochart, and everything checked out as good.
Instead, try this: run the pump up to almost full (like 9 gallons), then run it the rest of the way on the lowest setting. This way, you make sure that the pump cuts off in time. Once I started doing this, I have never gotten the P1457 again.
If that works, problem solved. If not, start with gascap.
Old Apr 29, 2009 | 02:34 PM
run what on the lowest setting?
Old Apr 30, 2009 | 05:06 AM
Run the gas pump on the lowest setting. Stop when it clicks the first time, and don't top it off after that. See if your code comes back.
That 100% fixed the same code on mine.
MarvKirsch
12
Mar 8, 2020 12:25 PM
paulatg
Honda Civic (2001 - 2005)
Jul 23, 2014 09:02 AM
integra_type-r
Nov 3, 2007 06:29 AM
integra_type-r
Oct 14, 2007 09:03 PM
JDMN
Mar 4, 2007 07:27 PM
