code 90 P1457
Old Oct 4, 2007 | 02:34 PM
integra_type-r's Avatar
Default code 90 P1457
ive been having this code on for almost 3 years now....pretty much replaced everything i could except the bypass solenoid near the gas tank because i don't know exactly were near the gas tank area does anyone have a picture or can take some picture?
thanks
parts replaced:
canister
canister purge valve
Gas Cap 2nd time
canister Shut valve
Old Oct 4, 2007 | 02:53 PM
ithrowpoop's Avatar
Default Re: code 90 P1457 (integra_type-r)
my friend has the same problem. has replaced the gas cap, canister and the valve on the canister. any advice would be cool.
Old Oct 4, 2007 | 04:55 PM
REDLINEtypeR's Avatar
Default Re: code 90 P1457 (ithrowpoop)
check to make sure your purge control sol. is working. If it is then you need to get some test equiptment to find your leak. poss. o-ring, hose clogged, or maybe a bum solenoid. Lots of test need to be done. Without the proper software you probably wont be able to fix it, one of those things us at the dealer hate b/c its a hard diag, s /b #03-001 Evap bypass solenoid valve fails due to corrosion. Try that if you haven't already. good luck
Old Oct 4, 2007 | 05:54 PM
JjuuN R's Avatar
Default Re: code 90 P1457 (REDLINEtypeR)
^ Yup, it happens when you try to fill your gas tank up too much...
Old Oct 13, 2007 | 11:36 PM
rpc08's Avatar
Default Re: code 90 P1457 (JjuuN R)
So what do you do to fix this code?
Old Oct 14, 2007 | 12:01 PM
BMaDOHC's Avatar
Default Re: code 90 P1457 (nos86)
most likely you need to go to the dealer. they will probably use a smoke machine to find a leak or you could have a clog, sometimes a small cobb web.
Old Oct 14, 2007 | 09:03 PM
rpc08's Avatar
Default Re: code 90 P1457 (BMaDOHC)
iam hearin alot of people replacing and fixing a number of different things regarding the evap cannister and still having a code what gives?
MarvKirsch
12
Mar 8, 2020 12:25 PM
integra_type-r
Nov 3, 2007 06:29 AM
jordan2305
Jul 18, 2007 08:45 PM
JDMN
Mar 4, 2007 07:27 PM
asdfsad
Jun 29, 2006 08:32 AM
