code 90 (Evaporative Emission Control System)
Old Feb 12, 2007 | 06:46 AM
integra_type-r's Avatar
Default code 90 (Evaporative Emission Control System)
code 90 (P1457)
have any of you guy had this problem before?
please help
Old Feb 12, 2007 | 06:57 AM
Doostur's Avatar
replace ur charcoal cannister.... its a an EVAP canister code
Dave_B's Avatar
Yep, sure have. Replaced the valve near the gas tank and it resolved the issue. GL.
Old Feb 19, 2007 | 10:25 AM
Default Re: (Dave_B)
I had a chance to change the Canister this weekend, drove for a while till the check engine light came back today...=/
so i guess ill try to replace the valve near the gas tank...where should i start?
is it under the back seat? what does it look like?
please help
Modified by integra_type-r at 11:35 AM 2/20/2007
Old Feb 19, 2007 | 11:30 AM
Doostur's Avatar
Could be something very simple like your gas cap isn't on tight etc... next thing id look at would be the Canister-purge valve...
Old Feb 19, 2007 | 11:34 AM
Doostur's Avatar
Wierd the canister usually fixed it.. reguardless you have a leak somewhere.... id look at all your hoses and valves in the line of fire also
Old Feb 19, 2007 | 02:57 PM
Dave_B's Avatar
I've never had the canister fix it. On our cars it's always been the valve.
Old Feb 19, 2007 | 06:06 PM
pyitrboy's Avatar
Default Re: code 90 (integra_type-r)
There are 3 solenoids that need to work properly. Canisters don't usually go that often...its usually one of the solenoids. You have to check each solenoid by applying 12v to it and see or hear if it clicks. The one that does't click is the defective one or it could just be a vacuum hose problem.
Old Feb 20, 2007 | 10:42 AM
Default Re: (Doostur)
i changed the gas cap and the canister purge valve and still didn't solve the problem
Old Feb 20, 2007 | 10:45 AM
Default Re: code 90 (pyitrboy)
where are the solenoids located? imma try to search up yahoo for pictures
Old Feb 20, 2007 | 11:16 AM
Doostur's Avatar
Old Feb 20, 2007 | 03:11 PM
pyitrboy's Avatar
Default Re: code 90 (Doostur)
There's a shut valve on the canister itself. it's just below the battery. The bypass
solenoid is by the gas tank. Each should click if you apply battery voltage to them.
Old Feb 20, 2007 | 03:38 PM
BMaDOHC's Avatar
order of correction in most cases is gas cap, canister shut valve, canister, 2-way/bypass valve, then purge but very rearly do we see them at the dealer. use the 12 volt method on each to see if they "click". if they all click then start looking at leaks in vacuum hoses.
Old Feb 21, 2007 | 06:48 AM
Default Re: code 90 (BMaDOHC)
this is the canister shut valve right?
the thing that sits on top of the canister?
Old Feb 21, 2007 | 06:54 AM
i couldn't find the bypass valve near the gas tank...(viewed from the bottom rear of the car)
any pictures?
thanks you guys
Old Nov 3, 2007 | 06:29 AM
arren123's Avatar
Just posting the Part # for the Evap ByPass Solenoid Valve because it is a PITA to find on the internet !
The part # is 17012-ST7-L01 and can be ordered at AcuraAutomotiveParts.org
(Its not listed on AcuraOemParts.com)
BTW. If you never found the valve in February, it is on the driver side of the gas tank underneath a plastic cover held on by three clips.
MarvKirsch
12
Mar 8, 2020 12:25 PM
goldenmustache
10
Apr 30, 2009 05:06 AM
gperry322
Jul 3, 2008 03:53 PM
integra_type-r
Oct 14, 2007 09:03 PM
JDMN
Mar 4, 2007 07:27 PM
