Water leak...
Hey guys, I have a problem. I have a 93 Ex and today when i got in the car it smelled a little funky. I checked it out and the passenger side floor was soaked. The water was coming for somewhere behind the rubber firewall mat, i'm wondering if anybody else has had this problem, or if anybody knows what might be causing this.
Thanks...
Thanks...
Either your air conditioner evaporator drain hose is blocked which you can clear the drain hose where it exits the passenger compartment. Or the evaporator drain hose is disconnected. All you have to do is secure the drain hose to the evaporator drainage tray under the dashboard. Thats it!!! Your all set to go.
I had a similiar problem. I bypassed the heater core and no longer have that problem. The only problem I have now is the lack of heat.
[Modified by civicb18b, 5:43 AM 8/17/2002]
Thanks...
Thanks...
