window problem!
Old Apr 28, 2009 | 05:43 AM
Laraboy's Avatar
New User
Default window problem!
I rolled down my window and now it won't go up! Going down wasn't a problem but now its stuck. when i push the switch i hear some thing and then nothing. has any one had this program and what can i do about it?
Old Apr 28, 2009 | 06:04 AM
fcm's Avatar
fcm
Old Fart
Default Re: window problem!
Kind of depends on what the problem is.
Which window, is it the only one with a problem?
MM&Y of car would help.
Is this the first time it has happened?
You said, "i hear some thing and then nothing" something like what, [a click, a grinding noise, a hum] ?
First thing I would check is the switch, could just be dirty.
Do you have or can you borrow a multimeter? 94
Old Apr 28, 2009 | 06:11 AM
Laraboy's Avatar
New User
its the driver side window and yes its the only one.
yes its the first time its happened and the noise is a hum and then it just stops.
Old Apr 28, 2009 | 10:11 AM
dtapia's Avatar
what year make and model is this mystery car ?
sounds like a broken window regulator.
does is sound like something hitting the glass like wires ?
Old Apr 28, 2009 | 10:48 AM
Laraboy's Avatar
New User
its a 2006 Element.
and when i push the button it hums a little and then just stops.
Old Apr 28, 2009 | 04:33 PM
fcm's Avatar
fcm
Old Fart
The window is jammed, why and how it's jammed there is no way of knowing without looking.
As mentioned, it could be a broken window regulator, or it may just be that the window is off the guide track(s).
A "hum" that stops after "a little" tells me the motor may be OK and a CB is cutting power to it because it's jammed.
You will need to pull the door panel and have a look. 94
Old Apr 28, 2009 | 06:38 PM
azndude27's Avatar
New User
dont mean to steal thread but i also have the same problem except whenever I roll my window all the way down and make it come back up it comes back up off the track -__-. I dont know why it does this and is annoying when I have to take off my door panel everytime to put it back. If i roll my window down halfway its fine but does anyone know why it does this? I recall someone told me something was bent but i forgot what it was called exactly.
Old Apr 28, 2009 | 09:11 PM
dtapia's Avatar
window regulator.
Costco
Sep 29, 2011 06:41 PM
nomoshing
Aug 6, 2008 10:53 PM
abdulmo86
19
Oct 18, 2006 09:35 PM
PhatBoy5015
14
May 8, 2006 05:59 AM
HondaMike17
Dec 2, 2005 04:49 AM
