anyone have a HOW TO for jdm vtec solenoid wiring?
I've been searching up and I know when you're using the jdm vtec solenoid with a usdm ecu you need to run a wire from A4 to D6. But my question is do you leave both wires connected in their pins and simply run a wire connecting the two? Or do you run both wires into one pin? Just want to make sure so I don't screw anything up...if anyone has a picture thread on how to do this it would be greatly appreciated, Thanks.
Thanks for the help man. But now I would like to know what you do with the ground wire coming from the vtec pressure switch? I have it grounded but its connected to the pressure switch, which is not being used. Am I good to go?
just run to any clean metal area and your good to go or you can tap it into one of the ground wire's in the engine harness or pin it . Any one of them will work .
I know this thread has been solved for one however I'm using a jdm obd2a gsr swap in a 00 civic si running the si ecu. Is this wiring trick necessary for my setup or no? I'm still trying to figure the Iab situation out as the obd2 gsr motors work on vacumn and not wiring so I'm hoping after this ckf trick I finally get vtec....any info would be appreciated.
AG
AG
AG
AG
Thanks for the info...The car is actually I 97 dx that has been completely rewired via si harnesses. now with the obd2b ecu which pins do I jump as I dont think its the same as the original poster....any help would be appreciated.
AG
AG
Ok I did that but still getting a code 22 I also grounded the black wire on the sensor plug...still no vtec and voila I now get a code 91 fuel something or other, please note I'm also throwing a code 65 secondary o2 just so you have a heads up.....please advise.
AG
AG
JSPECSIR
Oct 7, 2008 06:56 PM
nutball72
Aug 26, 2006 10:54 AM
