head gasket removal on block? how
Old Apr 23, 2009 | 11:42 AM
90goldhatch's Avatar
Default head gasket removal on block? how
I need some opinions as well as options on how to remove it, i've heard of Aircraft Stripping but the guy at autozone said it wouldnt work so yeah help here
Old Apr 23, 2009 | 11:56 AM
nico91civic's Avatar
Default Re: head gasket removal on block? how
is it a MLS gasket? if it is just get some pliers and pull on one of the rivets which shouldn't be on the surface of the block
Old Apr 23, 2009 | 12:00 PM
MLS?? uhhh the paper like one i guess
Old Apr 23, 2009 | 12:41 PM
EJ1_Sleeper's Avatar
headgasket or intake manifold gasket?
Old Apr 23, 2009 | 02:03 PM
headgasket on the block
Old Apr 23, 2009 | 02:28 PM
vtec=good's Avatar
I just went through this same crap last week. I was tod to use gasket remover but i went through like 3 cans with hardly any progress. Finaly i just used a razor blade and was really careful not to scratch the surface of the block, it takes forever though. good luck man
Old Apr 23, 2009 | 02:34 PM
ef-hatchcrap's Avatar
Use a soft wire brush on a drill that will take it off and not screw the mating surface
Old Apr 23, 2009 | 02:51 PM
r4BBiT's Avatar
i used gasket remover and very sharp knife to scrape it more, repeated the process a lot of times :D
Old Apr 23, 2009 | 05:02 PM
UfoTofU's Avatar
I ended up using gasket remover and a chisel.
Be sure not to gouge the mating surface at all!
I actually never finished because I had to move before I got all the parts and ended up putting my poor CRX into storage.
Let us know how it comes out.
Old Apr 23, 2009 | 06:41 PM
sgallagher's Avatar
3m makes a ROLOC bristle disc which is used on a drill or die grinder.I always use them works great on pretty much everything.
Old Apr 23, 2009 | 10:14 PM
yeah i just went ahead and bought a gasket scraper, next time ill probably go with
sgallagher method, but after this ill probably never change a head gasket ef this, anyways thanks for the help guys.
Old Apr 24, 2009 | 07:46 AM
89s1's Avatar
use the metal d16y8 headgasket if its the stock motor (si, dx, std/cx) doesn't matter what model. Comes off clean with 0 residue
If you have a b-series swap, use the oe gasket and it should be 3-piece metal.
Old Apr 24, 2009 | 07:54 AM
UfoTofU's Avatar
I like the looks of that.
Is that just a soft rubber / plastic bristle disc with some sort of light abrasive on the bristles?
Safe to use on the aluminum block?
Update : Great vid here that answers my questions :
http://www.youtube.com/watch?v=nXUZg-r-uww
Old Jun 2, 2009 | 02:26 PM
hondaman210's Avatar
New User
head gasket remover and a razor worked for me
Sajmon_LP
K Series
Aug 28, 2015 01:09 PM
WREKONIZE V8 KLR
Apr 6, 2005 10:40 AM
B20fun
Mar 22, 2004 10:29 PM
hondafanatic1
Feb 19, 2004 05:35 AM
civicmatt
Feb 21, 2003 09:59 PM
