94 del Sol Ls swap no spark *searched*
Old Apr 23, 2009 | 09:02 AM
GoHardEH2's Avatar
Icon3 94 del Sol Ls swap no spark *searched*
The Ls is a b18a1 block with b1 head..i have tha tranny and cylinder head ground..
Im using a dizzy that jus got pulled of a working car..
Main relay clicks..fuel pump primes
fuses are good under dash and under hood..
I been searching for info but none so far seemed to apply to my car..ugh plz help gotta get started today
Old Apr 23, 2009 | 09:28 AM
weavertime1's Avatar
Default Re: 94 del Sol Ls swap no spark *searched*
...and it ran fine with the other engine before you pulled it?
Old Apr 23, 2009 | 09:53 AM
EG6KILIN's Avatar
my guy is going thru the same thing on his b18a1 he is not getting no spark..
Old Apr 23, 2009 | 10:48 AM
GoHardEH2's Avatar
Yes i had a d15b in there b4 and never had any issues with it
Old Apr 23, 2009 | 11:03 AM
Former User's Avatar
Is there battery voltage on the Blk/Yel wire attached to the igniter with the key turned to ON(II). Does the CEL remain ON?
Old Apr 23, 2009 | 11:30 AM
GoHardEH2's Avatar
Cel remains on yes..
Old Apr 23, 2009 | 11:32 AM
Check for battery voltage at the dizzy. Does the CEL also remain ON steady (no code blinks) with the service connector jumped?
Old Apr 23, 2009 | 11:58 AM
GoHardEH2's Avatar
im goin bak to tha car now..but im not gunna b interet accessible..so can u gimme a preview of wat i need to do if i do or dont get voltage from tha dizzy/?
Old Apr 23, 2009 | 12:14 PM
kp's Avatar
kp
If you have power at the dizzy but still no spark, you may have a bad ignitor. If you have any spare b-series dizzys laying around, swap out the ignitors and try again.
Old Apr 23, 2009 | 12:23 PM
GoHardEH2's Avatar
mtha dizzy on there jus got takin off a working car tho
Old Apr 23, 2009 | 01:39 PM
If you don't have power at the dizzy, then check for blown fuses, a broken Blk/Yel wire, or a bad ignition switch.
If you have power at the dizzy, then check the Yel/Grn wire that goes between the igniter and ECU for continuity. If the wire is fine, then the ECU may be bad.
Old Apr 23, 2009 | 07:50 PM
GoHardEH2's Avatar
Lock tha thread delly is running..
Old Apr 26, 2009 | 03:19 PM
kp's Avatar
kp
wtf, no follow up? what was the problem?
Old Apr 26, 2009 | 03:26 PM
Maverick's Avatar
Team Purple
so what was it?
hexadec0079
Mar 4, 2014 09:36 AM
JesusGLS
Jan 13, 2013 04:59 AM
aemintgsr
15
Aug 11, 2011 03:53 PM
blazianasian06
Feb 15, 2011 07:07 AM
boostedegls
16
Aug 31, 2010 03:41 PM
