Horn Wiring: Momo hub and NRG quick release
I searched, but couldnt find anything.
I have a momo hub and an NRG quick release. My problem is that the hub come with 1 black wire (im assuming for ground) and the QR has 2 wires (for ground and power). What do i connect the power wire on the quick release to? Since there's only one black wire coming from the hub.
I just wanted to see if anyone had success in wiring up the horn with configuration, because im not sure how to do it.
Thanks.
Thanks.
the wires arent for ground and power its one or the other they get plug into the switch so when you push it it completes the circuit, it may be that the hub uses itself as one of the contacts, on the wheel there is a leaf spring thing that connects to the little thing on the steering rack that dissengages the turn signals, on the oem wheel the leaf spring is connected to the wheel body itself and then the switch connects back to the body. This doesn't address any of you specifc problems but might help
http://hondaswap.com/civic-crx-ef/ho...g-wheel-73433/
thanks..
i guess ill just fiddle around with the wires and see what works. i just wanted to see if anyone had experience with this set up (since the nrg slim hub is different) and could tell me if im supposed to hook up another wire for power or something.
crdcz03
Sep 10, 2020 09:23 PM
Chance EG
Jul 25, 2017 06:22 PM
johnmota
Jul 13, 2015 06:37 AM
