Think I'm screwed.. Rays Lug Nuts
Old Aug 15, 2002 | 06:20 PM
StageOne's Avatar
Default Think I'm screwed.. Rays Lug Nuts
OK, I seem to have "misplaced" the key to the (Rays/Volk) special seven-sided lug nuts. Does anyone know if the keys are all the same and where I can get another one without purchasing anther entire set???
Currently screwed and patiently awaiting helpful answers.
And this is something to think about when you are planning to purchase a set of lug nuts to go with your fancy new wheels. Do you want added safety or the assurance of easy removal!!!!
Old Aug 15, 2002 | 06:23 PM
TypeR76's Avatar
Default Re: Think I'm screwed.. Rays Lug Nuts (StageOne)
yes, they are all the same
Old Aug 15, 2002 | 06:44 PM
00-ITR-373's Avatar
Default Re: Think I'm screwed.. Rays Lug Nuts (TypeR76)
Shawn..I have some Rays lugs. Swing by and we'll try to get yours undone.
Sound good?
-This is troy by the way.
Old Aug 15, 2002 | 06:57 PM
kkim's Avatar
I kept mine in my glovebox so I'd always know where it was. Also, if you get a flat, you're gonna need that thing to change the tire.
Old Aug 15, 2002 | 08:59 PM
LiKe_WhOa!'s Avatar
Default Re: Think I'm screwed.. Rays Lug Nuts (kkim)
i kept my key in my car and when it was stolen the thieves were easily able to steal my rims and tires and 5 lug and everything else...
Old Aug 15, 2002 | 09:13 PM
91vtecripper's Avatar
Default Re: Think I'm screwed.. Rays Lug Nuts (LiKe_WhOa!)
are those volk locks better than the kyokugen locks and how much are they?
Old Aug 15, 2002 | 11:32 PM
Ibuprofen's Avatar
Default Re: Think I'm screwed.. Rays Lug Nuts (91vtecripper)
are u referring to the kyokugen nuts?
get rid of those p.o.s.'s! took me 6 hrs to remove those nuts earlier today while switching out the springs to kgmm (will post pic soon). every single lug was stripping. unbelievable. ended up having to buy a couple 15mm 12 sided sockets and hammered them in there to get the ones that were lost causes already..
fortunately, after a talk with mackin industry with one of the reps, he was able to hook me up with a new key that was redesigned (thankfully). this one worked a lot better, but was still borderlining as far as grip was concern.
my suggestion as with many others who i've known with the same lugs is to take them off and throw them away. They are a pain in the *** even if u properly tq it and not use impact wrenches.
but to answer your question, your best bet would be to get it thru a local shop. Mackin industry *supposingly* does not deal directly with endusers.
Old Feb 24, 2003 | 05:45 PM
Asahi's Avatar
In case someone else finds this with a seahc, this is wrong. There are at least 5 different keys according to Mackin Industries. ALso I ahve tried a key that did not fit. They are numbered. I have key # 27 and my freind had key # 37.
Old Feb 24, 2003 | 05:47 PM
98itR484's Avatar
Default Re: Think I'm screwed.. Rays Lug Nuts (Asahi)
And my friend has key 47, so they are not all the same
Todd00's Avatar
I said I don't want a title!
True, they are not all the same. I happened to have the proper Rays key for his lugnuts, so he just used mine to remove them. Very fortunate!
Old Feb 24, 2003 | 05:49 PM
Asahi's Avatar
Default Re: Think I'm screwed.. Rays Lug Nuts (Todd00)
does anyone have 4 non locking black rays they woudl want to sell?
Old Feb 24, 2003 | 06:26 PM
BRICKHEAD's Avatar
I have owned two sets of Rays lugnuts and there are different keys as already said. This may sound strange but I think Craftsman sells a socket the consists of many small rods inside of it. When you put it on a stripped bolt or even just a regular bolt it adapts to the size desired. It is not a perminamt solution just something to have in case of a flat. I am sorry that I dont know what it is called but it does work and could get you out of a jamb if need be. Hope this helps.
Old Feb 24, 2003 | 06:36 PM
1CoolR's Avatar
After reading through this thread because I want(ed) to purchase a set, does anyone sell black locking semi-lightweight non-open-ended lug nuts with 2 keys ?
Or can you buy another either at the same time, or later from Mackin (or a dealer) ? We should learn from you guys now, rather than posting later that it happened to us.
Old Feb 24, 2003 | 06:41 PM
Casey's Avatar
Default Re: Think I'm screwed.. Rays Lug Nuts (1CoolR)
gator wrench...that thing that has the spring loaded splines that will form to any bolt etc
Old Feb 24, 2003 | 07:51 PM
1CoolR's Avatar
Default Re: Think I'm screwed.. Rays Lug Nuts (Casey)
So you're saying there's basically no protection with Volks lug nuts with that wrench anyone can buy from Sears ?
Old Feb 24, 2003 | 08:00 PM
2k1_ITR_0736's Avatar
um, kinda, but that thing breaks alot. so they might get a wheel or 2.
Old Feb 24, 2003 | 08:16 PM
MiraiZ's Avatar
Default Re: Think I'm screwed.. Rays Lug Nuts (2k1_ITR_0736)
yeah...it must suck being screwed by Ray's nuts...
sorry ...thought it must be said
Old Feb 24, 2003 | 10:00 PM
01CWITR's Avatar
Default Re: Think I'm screwed.. Rays Lug Nuts (MiraiZ)
one of my Ray nuts is missing while i was driving so i bought one Blue Spoon nut to replace it anyone have one Blue Rays nut for sale ? let me know thanks !!
TsujenDB1
Mar 19, 2011 04:45 PM
importboi22
Sep 25, 2006 04:44 PM
B18CYAAA
Sep 2, 2003 07:13 PM
Sohc Driver
34
Dec 25, 2002 02:04 PM
threatcon13
May 4, 2002 10:25 AM
