i gotts turbo lag
Old Apr 18, 2009 | 10:28 PM
hyprhero's Avatar
Default i gotts turbo lag
ok i got a b18c1 in my hatch.its got a built bottom end pistons rods etc.running t4 turbo 2.5 downpipe exhaust and ic piping.everything was fine till i installed a bigger intake manifold port matched to the new throttle body at 68mm o and i did cam gears.the problem is now what i believe to be a turbo lag.the boost is kicking in way later like at 4 or 5 rpm.can anyone help me figure out how to solve this problem?im running 13psi do i need more?bigger turbo?help please
Old Apr 18, 2009 | 10:46 PM
B16Drag's Avatar
Default Re: i gotts turbo lag
I'm assuming you have checked for leaks already... Check silicone clamp areas and also bolts on the intake manifold where you touched or removed.
Old Apr 18, 2009 | 10:53 PM
thunder2709's Avatar
Bigger IM = More space to fill
More space + same turbo pushing the same amount of air = More time to generate the same PSI
This is assuming there are no leaks
Old Apr 18, 2009 | 10:56 PM
hyprhero's Avatar
ive checked the ic piping and some other places. ill double check but if its not that then what do i do
Old Apr 18, 2009 | 10:58 PM
hyprhero's Avatar
so should i push more psi?
Old Apr 18, 2009 | 11:33 PM
All_Motor_2o9's Avatar
Question answered dude, lol.
Old Apr 19, 2009 | 08:59 PM
blinx9900's Avatar
You have a T4 turbo and boost comes on at 4-5krpm, whats the farking problem?
Old Apr 19, 2009 | 09:19 PM
Oh and I didn't look closely enough, you really should be running a 3" downpipe... 10PSi+ is 3"+. Might help some. And what fuel management system are you using? What tuning? All these facts play in this equation.
simjosh
Mar 30, 2016 10:59 PM
dont_tri
Jul 1, 2008 04:40 AM
sykotic
Mar 15, 2005 03:05 PM
KeithGSR
Jun 1, 2004 10:52 PM
95gsrturbo
May 6, 2004 05:43 AM
