turbo spooling late- help?
Old May 5, 2004 | 07:27 AM
95gsrturbo's Avatar
Default turbo spooling late- help?
i pulled the turbo this weekend to replace the manifold gasket that was leaking and now i dont reach full boost until about 5K rpm where it used to be 3500-3750 or so--
is it possible that if i have the oil feed pinched it would cause this??
what else could be the problem?
checked the manifold and piping-- no leaks, torqued everything down too.
Old May 5, 2004 | 08:05 AM
J337_UNIT's Avatar
Default Re: turbo spooling late- help? (95gsrturbo)
the fact that u mentioned you have no leaks boggles me.. Last night after i got my car tuned it was driving perfect.. spooling at around 3400 rpm.. then shortly after it wouldnt hit full boost anymore at all.. everything looked good untill i removed the RUBBER (DOH!) coupling from the turbo to the IC pipe where it blows into and there was a hole in it. So if i were u i would try and reall inspect those couplings. Thats my 02 cents.
Old May 5, 2004 | 10:52 AM
95gsrturbo's Avatar
Default Re: turbo spooling late- help? (J337_UNIT)
thanks for ther advice- ill recheck the couplings for cracks. etc...
Old May 5, 2004 | 11:35 AM
Rod.'s Avatar
not to take over the thread. Can you loose vaccumm through a hole on the silicon coupler????
Old May 5, 2004 | 11:38 AM
TRE_'s Avatar
sounds like you've got a leak before the turbo... somewhere on the turbo manifold, either where it mates to the head or to the turbo itself. triple check all of your gaskets, and listen for leaks. check all your vacuum lines and couplers too.
Old May 5, 2004 | 03:25 PM
95gsrturbo's Avatar
Default Re: turbo spooling late- help? (THE_HX)
checked all leaks -- none-- friend is having the same prob with the greddy-- its not only spooling bad for him but boost is falling off too- not holding-- cant figure why
possibly this SHi^^y wastegate-- i think im gonna trash my whole setup after this summer and get a inline pro with t3/t4 E
Old May 6, 2004 | 05:43 AM
95gsrturbo's Avatar
bump
simjosh
Mar 30, 2016 10:59 PM
nihad
Nov 30, 2008 06:40 PM
95whitegizzer
Jun 28, 2006 05:21 PM
sykotic
Mar 15, 2005 03:05 PM
Go Fast Civic
Dec 30, 2004 12:28 PM
