Help ! Turbo B16 .. Valve seals ?
Old Apr 17, 2009 | 09:00 PM
Joeski99Si's Avatar
Default Help ! Turbo B16 .. Valve seals ?
So i recentenly boosted my b16 on 8 psi i only made 230whp, tuned on eCtune . . Im burning oil , it is blowing white smoke ! ! ! What do you think my issue is ? iv done comp. test all 4 cylinders are between 184-190 . Im wondering if it could be valve seals causing power loss & burning oil? I did notice un-burt oil on bumper before i boosted it.
im also having trouble with starting sometimes, i donno if that has anything to do with it or not . . . .
And this isnt a cheep turbo set-up either that is causing power loss, its all garrett, and tial, rev maxx set up.
anyone have there dyno #'s or sum input or idea's ?
Old Apr 17, 2009 | 10:01 PM
B16Drag's Avatar
Default Re: Help ! Turbo B16 .. Valve seals ?
Whats your entire setup... Turbo size, cams, etc... stock b16?
Old Apr 17, 2009 | 10:05 PM
Joeski99Si's Avatar
garrett t3/t4 .57 / .63 A/R.. rc 750 inj, walbro 255,
Stock B16 internals top and bottom end
Old Apr 18, 2009 | 12:47 AM
wunfstgsr's Avatar
Loved
Community Favorite
doesnt sound bad for a stock b16!
Old Apr 18, 2009 | 01:43 AM
inspector01's Avatar
Assuming a stock B16 is around 130-140 whp, you made 90-100 whp for 8 psi. A good setup should gain about 15 hp/psi, yours did about 12 hp/psi, which is pretty common gains.
Old Apr 18, 2009 | 04:04 AM
Joeski99Si's Avatar
just seems like the motor maybe a little weaker than normal . .
Old Apr 18, 2009 | 05:05 AM
Str8 outta Cliff's Avatar
What size is your exhaust?
Old Apr 18, 2009 | 05:13 AM
Joeski99Si's Avatar
downpipe is 2.5, and im sure the exhaust is 2.5 also it's a APEXI WS2
Old Apr 18, 2009 | 05:33 PM
DcYo's Avatar
maybe turbo seals? how thick is the smoke?
Old Apr 20, 2009 | 02:00 PM
Joeski99Si's Avatar
well when it was first dyno'd it was thick and filled up whole shop, but i think most of that was blow-by. then the smoke thinned out, but it is still smoking a little bit not real thick!!
But like i said i was going threw oil b4 i even boosted, about 1 1/2Qt. in 2000-3000miles, and some of it seems to be un-burnt oil on bumper.
Maybe try a leak-down test ?
Old Apr 20, 2009 | 05:33 PM
DcYo's Avatar
leakdown and compression test would be good. also look for oil in the charge pipes on the compressor side of the intercooler.
Old Apr 22, 2009 | 08:02 PM
Joeski99Si's Avatar
well did a leak down 2day. .. head gasket is blown, in between cylinder 1&2
Old Apr 23, 2009 | 06:33 AM
redlinetuning's Avatar
Time for a cometic.
1sikhatch
Jan 19, 2012 03:44 PM
iamthefollower
Dec 11, 2009 07:22 AM
b16ajdmrex
May 23, 2009 09:20 AM
joethejoeman
Feb 6, 2007 04:37 PM
alex288
Apr 28, 2006 12:50 PM
