gsr turbo headgasket
Old Apr 17, 2009 | 07:11 AM
rick_rabies's Avatar
I'm not Rick!
Default gsr turbo headgasket
Gsr turbo 13lbs of boost...will a felpro head gasket work? Is there big NO on these?
Old Apr 17, 2009 | 07:22 AM
93egSLEEPER's Avatar
Default Re: gsr turbo headgasket
get an OEM one
Old Apr 17, 2009 | 07:27 AM
I'm not Rick!
oem blew on me in the first 5 miles at .4 lbs of boost
Old Apr 17, 2009 | 07:29 AM
OEM 3 layer? there was definately something wrong... i have been running mine on 10psi for 6k now no problems. was it new?
Old Apr 17, 2009 | 07:33 AM
turbojdmhatch's Avatar
most people stick to OEM more than people think...do u have stock head bolts or do u have after market head studs? u should buy an OEM headgasket and buy some arp head studs...
Old Apr 17, 2009 | 07:36 AM
I'm not Rick!
arp head studs, 3 layer, new, i did 65lbs of torqe...il try 80lbs this time
Old Apr 17, 2009 | 07:45 AM
you torqued the nuts to 65? they are supposed to be 80.... probably a reason it blew.
Old Apr 17, 2009 | 07:46 AM
did u not read the instructions on how tight they are suppose to go that come with the studs?
Old Apr 17, 2009 | 07:50 AM
I'm not Rick!
i didnt get a paper like people are saying jsut the studs and lube. so i had to look online and i saw 60-67lbs so i set it at 65. 80 then right?
Old Apr 17, 2009 | 09:09 AM
senser1080's Avatar
Screw the OEM headgaskets, go with a Cometic one bored to the right size. Yeah, also srsly torque them correctly.
yfz
Dec 12, 2010 07:13 PM
LS_VTECteggy
Mar 15, 2010 06:10 PM
teddy_dc2
Jun 28, 2006 05:02 PM
