head studs
Old Mar 15, 2010 | 03:11 PM
LS_VTECteggy's Avatar
Default head studs
so I'm about to take my head studs off to remove my head, do I have to buy new head studs or can I reuse the old ones and retorque it?
Old Mar 15, 2010 | 03:28 PM
mouab18c1's Avatar
Default Re: head studs
OEM? or aftermarket?
Old Mar 15, 2010 | 03:43 PM
idk cuz I bought it with an ls/vtec and idk if he changed out the headstuds with aftermarket ones but what if it is OEM? can I reuse it? Vice-Versa for aftermarket?
Old Mar 15, 2010 | 03:49 PM
mouab18c1's Avatar
Usually for an ls/vtec you need aftermarket such as ARP headstuds. If they are Arp and depending on mileage; you could reuse them as long as they have don't have alot of miles on them. You should be able to tell by taking off the cam caps.
Old Mar 15, 2010 | 03:50 PM
alright thanks
Old Mar 15, 2010 | 04:33 PM
2.0Da9's Avatar
if they're OEM headstuds you DEFINITELY want to change those out since you're running lsvtec, check out the threads on the studs and see how it looks
Old Mar 15, 2010 | 06:10 PM
PaulMc's Avatar
Painfully Stupid
If they're OEM, you should replace them. Replace them with ARP, with ARP you can remove them again with no damage done. They're stronger studs then OEM and other aftermarket brands.
kreatekustomz
Jun 14, 2009 06:00 PM
rick_rabies
Apr 17, 2009 09:09 AM
LSEGHATCH
Aug 17, 2005 03:11 PM
jDMJeRk
Apr 8, 2004 12:26 AM
