Help Bad compression...
So i did a compression test on my 94 civic hatch with a b18c swap. It read 40-55 for the first cylinder, 94 for the 2nd, 140 for the 3rd and 150 for the last. I hear something tapping so im guessing its my valves. Is there anyway or test to figure out if its really my valves w/out takin the head off? Im just hoping its not my rings or something. I dont blow out any black smoke or anything at all out my exhaust. If its my head should i just get new valve, springs & retainers or find a complete b16 head and slap that on. Help! this is my everyday car. if its the valves would it be safe to run that 4 a lil while? cuz i think ive been running like this 4 a while already and nothing has gone wrong so far...
Thanks for your time.
Re: Help Bad compression...
Hmm low compression on adjacent cylinders eh? Sounds like more of a head gasket problem to me. The gasket is burnt through between cylinders.
And that would cause the tapping noise?... Im pretty sure the valves tapping though , plus i did a valve lash adjustment not too long ago.
when its warmed up all the way its pull likes poop. when its between cold and warm its pulls hard. i thought its was an ignition prob so i replaced the plugs, wires and rotor...
Head gaskets only puff white smoke when they are burned through to a coolant passage. In this case the gasket sounds like its burned through to another cylinder. Pull the head and find out what it is. And try not to drive it anymore.
Well, since you did a valve lash adjustment...it could mean that you adjusted them too loose and this produce the clicking noise you described. This will also cause the engine to not run as well, poor gas millage, and loud operating sounds. On the other hand you can do a leak down test and listen if there is a leak in between the head and block. Or open your radiator cap and look for signs of bubbles, Which means combustion gas has entered the coolant system. Indicating cracked cylinder walls or in this case its a blown head gasket. Keep us updated.
if its a HG y would it have that tapping noise?
On the 92-95 honda civics the specs want you to adjust it when its cold.Just make sure theres only a little drag instead of too much or none. If you tightened it too much then the valve may be stuck open and burn.
B18C5_VTEC
10-08-2007 02:54 PM
slowazzhatch
13
06-01-2004 08:51 AM
