what would be the best tranny for this setup
Old Apr 16, 2009 | 10:43 AM
turboblack2door's Avatar
Default what would be the best tranny for this setup
jdm d15b fjt custom lengh rods 75.5mm vitaras holset hx35 evo 550s injectors CSAddic manifold jgs 40mm wastegate 20lbs boost. car is a gutted 10pt cage 92cx. I have a cx tranny just not sure if i want to use it
Old Apr 16, 2009 | 11:08 AM
Nighthawk7thGen's Avatar
Default Re: what would be the best tranny for this setup
Ew. CX tranny
Get an EX/Si trans. They're great for acceleration.
(though the 180mph top speed on the CX trans's 5th gear is tempting.... .... ....jk.)
Old Apr 16, 2009 | 11:21 AM
tazeat's Avatar
EX/Si with a longer 5th I would think would be ideal, I like to cruise at night a little fast and you rev a tad on the high side with the stock 5th imho, but I'd take a stock EX/Si over the CX any day :p.
Old Apr 16, 2009 | 11:47 AM
my main concern with anything other than the cx tranny is that when the holset spools at 5k rpm it is going to blow the traction to hell and i think the cx may allow me to accelerate more without the loss of traction or at least not as much loss of traction. Does that sound wrong?
Old Apr 16, 2009 | 11:53 AM
civic_driver's Avatar
That sounds logical. You will lose acceleration and gain traction.
Old Apr 16, 2009 | 12:01 PM
thats kind of what i was thinking but i just dont know if my 1/4mi times are goint to suffer
Old Apr 18, 2009 | 10:44 AM
with the cx tranny, once you get traction it will be slower than the ex, but with the ex you will be slow until you get traction and then it goes much faster than the cx tranny. either ask someone that has done this before or try it out yourself and let us know which is a better option if you get that chance.
Old Apr 18, 2009 | 11:07 AM
batallic's Avatar
ex tranny
Old Apr 18, 2009 | 11:26 AM
NightCat's Avatar
I have an EX Tranny...and i really wish my 5th gear was taller.
Old Apr 18, 2009 | 11:32 AM
esean93's Avatar
use the cx tranny.longer gear trannys go great with boost.if i was going to keep my eg and boost it,id take a ls tranny over a b16 anyday!
Old Apr 18, 2009 | 02:50 PM
tazeat's Avatar
Honestly the conflicting information in the thread says you should start a thread somewhere in the transmission or forced induction section... Where someone actually knows the answer.
I would think the shorter gears would put more torque to the ground throughout the whole range, yes you may have problems with traction in first and second, but I would think it would more than make up for it after imho, but I don't drive a boosted car so what do I know. Also read up from MFactory's website, there is a lot of helpful tranny info there.
dylokjai
Dec 12, 2006 09:17 AM
turbotime
10
Sep 26, 2003 12:20 PM
xXx Justin xXx
May 11, 2003 09:32 PM
KoRE
13
Jun 17, 2002 04:01 PM
