help my exhaust came off my headers?
Old Apr 15, 2009 | 08:47 AM
Ekzc91's Avatar
Default help my exhaust came off my headers?
how can I fix this what tools will I need like the B pipe is hanging lose from the intake manifold?
Old Apr 15, 2009 | 08:59 AM
EL Vap133's Avatar
Default Re: help my exhaust came off my headers?
Did anything break or did the bolts come loose somehow?
Old Apr 15, 2009 | 09:00 AM
Ekzc91's Avatar
I dont Know I would have to lift It and check I was going a little fast and then I heard like bolts unfastening and all of a sudden it sounded really bad and the car was shaking like crazy and when I pulled over and saw the b pipe was just hanging loose
Old Apr 15, 2009 | 09:06 AM
EL Vap133's Avatar
Those bolt sshould be on tight. Maybe something got stripped?
Old Apr 15, 2009 | 09:10 AM
hondamark35's Avatar
aftermarket flange with regualar bolts or factory type with spring bolts/flex joint?
you'll just need regular hand tools to fix it, socket set, metric wrenches.. and a floor jack or ramps to get under it. that is once you figure out exactly what to fix.
Old Apr 15, 2009 | 09:19 AM
instructor74's Avatar
or the flange rusted off around the b pipe and will need to be replaced
Old Apr 15, 2009 | 09:32 AM
MonkeyMagic's Avatar
what? you mean header? intake manifol doesn't touch exhaust wtf?
i can't get enough info from the post to even help... wut??
Old Apr 15, 2009 | 09:40 AM
si1320civic's Avatar
Old Apr 15, 2009 | 09:45 AM
kp's Avatar
kp
Just getting down on your hands and actually looking under your car would be very beneficial at this point.
Old Apr 15, 2009 | 10:12 AM
EL Vap133's Avatar
Jack the car up real quick and use some jack stands to inspect the damage done if any.
Old Apr 15, 2009 | 10:42 AM
ek4_b16a's Avatar
yea it may be possible that your exhaust bolts might've just rusted off. take a look under your car to see what needs to get fixed. probably nothing major. gl
Stan Moore
Feb 21, 2015 11:22 AM
importtuner51
Jul 8, 2012 11:15 AM
Sardawg
Jun 4, 2005 07:26 AM
GSRerrr
Mar 4, 2005 08:50 PM
uranazo
26
Jan 14, 2004 03:28 PM
