Hub bearing
Old Apr 14, 2009 | 09:05 AM
N3GUM's Avatar
Default Hub bearing
Here's the story, i got a JDM ITR 5 lug conversion and my hub bearing went bad. So i cant seem to figure out, can i replace this with a USDM bearing of do i have to find a JDM one.... Or will a 99-00 CVR bearing work? I need as much input on this as possible. Thanks Honda-tech!
Old Apr 14, 2009 | 11:32 AM
Redcoupe's Avatar
Default Re: Hub bearing
Which hub, front or rear?
Rears are probably the same.
I know the ITR and 99-00 Civic Si part numbers for the front are the exact same so I ordered mine thru a local Honda dealership but then again, I have the USDM knuckles.
For some reason, I remember them being the same bearing from jdm to usdm. Hopefully more will come in to clarify.
-Jarrod
Old Apr 14, 2009 | 02:17 PM
N3GUM's Avatar
-Jarrod
Sorry, it's the passengers side front. I can't figure this out...
Old Apr 15, 2009 | 07:07 AM
jomama's Avatar
you would think they're different for the fronts from USDM to JDM since the axles you'd use are different... GL
Old Apr 15, 2009 | 12:05 PM
Beasty18C5's Avatar
yeah its a possibility you'll need the cr-v bearing since they use same hub as the jdm look at the part numbers of the hond-crv bearing and an itr bearing. Keep us posted its good to know
Old Apr 15, 2009 | 04:23 PM
Redcoupe's Avatar
To be honest, I'm pretty sure the part numbers are the same.
Let me cross refrence them.
*They aren't the same. *
Old Apr 15, 2009 | 06:11 PM
thabao's Avatar
Either try 99-00 crv or later year prelude since they both use 36mm axles.
Old Apr 16, 2009 | 06:11 AM
sheekdude's Avatar
should be 97+ crv hub...
Old Apr 18, 2009 | 07:05 AM
N3GUM's Avatar
I cant find anything out. I still need help!
Old Apr 18, 2009 | 08:54 AM
EM1 Loi's Avatar
i changed mine before and i got mines from a crv
Old Apr 18, 2009 | 12:11 PM
ken9's Avatar
Just send the car to the mechanic and tell them you have a problem with your bearing. I have this problem before so it will save you time, problem, money, and frustration. If you not sure about it send it to the mechanic. I had problem with my bearing and it was horrible and good thing that my mechanic biddy help replace it with new one.
Old Apr 19, 2009 | 08:55 AM
bks84's Avatar
Loved
The car has a 5 lug conversion, therefor when they order a bearing for that the car would require if it were stock... it'll most likely be the wrong one.
kamciu80
Sep 3, 2010 10:42 PM
antaren
Nov 6, 2007 05:44 PM
NsX_CrX
Jun 14, 2006 09:16 PM
Redline96LX
Oct 19, 2005 03:19 PM
boostedcivicsir
Jul 2, 2003 01:44 PM
